Renn shifter install |
partwerks |
Sep 22 2013, 08:39 AM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Finally invested in a Renn shifter, and hopefully will put to bed all those shifting woes once and for all!!
Not that my mechanic doesn't know what he is doing, but are there any off the wall issues that might be good to know before we start the project?? I have all new bushings otherwise. |
JWest |
Sep 22 2013, 08:13 PM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
Finally invested in a Renn shifter, and hopefully will put to bed all those shifting woes once and for all!! Not that my mechanic doesn't know what he is doing, but are there any off the wall issues that might be good to know before we start the project?? I have all new bushings otherwise. Mechanics tend to do a bad install more then novices, because they won't read the instructions and specifics, but novices are careful, pay attention, and this is just not that difficult. Some mistakes I have seen: The metal bushing in the bottom of your shifter needs to be moved over to the RennShift with the shift rod clevis. Adjust so the shift stick does not move to either side when engaging 2nd gear - the gear slot in the trans should align with the shifter springs. Back off the stops so they are not touching during full engagement, as above. |
partwerks |
Sep 22 2013, 09:01 PM
Finally invested in a Renn shifter, and hopefully will put to bed all those shifting woes once and for all!! Not that my mechanic doesn't know what he is doing, but are there any off the wall issues that might be good to know before we start the project?? I have all new bushings otherwise. Mechanics tend to do a bad install more then novices, because they won't read the instructions and specifics, but novices are careful, pay attention, and this is just not that difficult. Some mistakes I have seen: The metal bushing in the bottom of your shifter needs to be moved over to the RennShift with the shift rod clevis. Adjust so the shift stick does not move to either side when engaging 2nd gear - the gear slot in the trans should align with the shifter springs. Back off the stops so they are not touching during full engagement, as above. I'll skip over the first line for the mechanic, but pass along the extra tips part, just in case!! |
partwerks |
Sep 22 2013, 09:13 PM
Finally invested in a Renn shifter, and hopefully will put to bed all those shifting woes once and for all!! Not that my mechanic doesn't know what he is doing, but are there any off the wall issues that might be good to know before we start the project?? I have all new bushings otherwise. Mechanics tend to do a bad install more then novices, because they won't read the instructions and specifics, but novices are careful, pay attention, and this is just not that difficult. Some mistakes I have seen: The metal bushing in the bottom of your shifter needs to be moved over to the RennShift with the shift rod clevis. Adjust so the shift stick does not move to either side when engaging 2nd gear - the gear slot in the trans should align with the shifter springs. Back off the stops so they are not touching during full engagement, as above. I'll skip over the first line for the mechanic, but pass along the extra tips part, just in case!! I wonder how that's going to work, since my first gear is capped off, and actually use what would be second gear for first, and so on? How will that work on adjusting it?? I may as well try and get some of these questions answered before the fact! |
JWest |
Sep 23 2013, 07:08 AM
I wonder how that's going to work, since my first gear is capped off, and actually use what would be second gear for first, and so on? How will that work on adjusting it?? I may as well try and get some of these questions answered before the fact! With a locked-out 1st gear, the auto-reverse lockout will not function, as it is primed or cocked when in the first gear slot. You can use the manual lockout, or you can simply stiffen the spring for the reverse gate with the included shims. I didn't mean to be harsh generalizing about all paid mechanics. But those have been the worst offenders and the customers who are apprehensive usually do a fine job. I have also had many instances of pros buying shifters from me after being impressed with the result of one they installed for a customer. |
Lo-Fi Version | Time is now: 28th May 2024 - 10:07 PM |
