Renn shifter install |
partwerks |
Sep 22 2013, 08:39 AM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Finally invested in a Renn shifter, and hopefully will put to bed all those shifting woes once and for all!!
Not that my mechanic doesn't know what he is doing, but are there any off the wall issues that might be good to know before we start the project?? I have all new bushings otherwise. |
Tom |
Sep 22 2013, 09:35 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Just as a by the way, an early 80's 911 SC boot caps off the renn shifter very nice.
Tom Attached thumbnail(s) |
JWest |
Sep 23 2013, 07:12 AM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
Just as a by the way, an early 80's 911 SC boot caps off the renn shifter very nice. Tom Yes, and they are suprisingly inexpensive. Porsche part# 911-424-181-01. The RennShift does come with its own boot, but if you are after a more of a factory appearance this works well. |
rwilner |
Sep 23 2013, 06:55 PM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
Make sure your clutch tube is fully welded at all the right points.
With the rennshift, the shift rod will sit lower in the tunnel. If your clutch tube has let go at the front, you may not be able to get into the 4/5 plane. Other than that, I highly recommend you install it yourself. It's simple to do, rewarding, and you will know it's done right. The job isn't even greasy...you don't even need to jack the car up. Plus, you can tweak the shifter adjustment until it's perfect after driving in real world conditions. |
Lo-Fi Version | Time is now: 28th May 2024 - 11:11 PM |
