| rgalla9146 |
Sep 23 2013, 08:31 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,950 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Does the AAR on a 73 2.0 ever close completely ?
Does it operate on 12V only or does it rely on engine ambient temp to operate as well ? I have a high idle after adjusting timing ( with known factory timing marks ) and checking all areas for vacuum leaks. If I cap the AAR hose the idle is normal and there is adjustment left on the idle screw. The points plate moves freely with vacuum in both directions. TIA |
dangrouche
... Sep 23 2013, 08:35 PM
r_towle It's a coiled up spring.
Blast a can of pb bl... Sep 23 2013, 09:10 PM
76-914 Remove it and as Rich said PB it or WD40 it. Placi... Sep 24 2013, 09:08 AM
worn
... Sep 24 2013, 10:21 AM
rgalla9146
Does the AAR on a 73 2.0 ever close completely ?... Sep 24 2013, 04:24 PM
Dave_Darling If that fails (hopefully it won't) after sever... Sep 24 2013, 09:57 PM
rgalla9146
If that fails (hopefully it won't) after seve... Sep 25 2013, 10:44 AM
rgalla9146
If that fails (hopefully it won't) after sev... Sep 25 2013, 10:57 AM
9fourteen14
[quote name='rgalla9146' post='1931704' date='Sep... Aug 23 2016, 01:21 PM
442nd914s I found this awhile back. Maybe it might help some... Sep 25 2013, 12:23 PM
rgalla9146
I found this awhile back. Maybe it might help som... Sep 25 2013, 09:28 PM
Dave_Darling The cylinder with a slit in it is the "rotary... Sep 27 2013, 08:20 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:30 AM |
