> Auxilary air regulator, proper operation
rgalla9146
post Sep 23 2013, 08:31 PM
Does the AAR on a 73 2.0 ever close completely ?
Does it operate on 12V only or does it rely on engine ambient temp to operate as well ?
I have a high idle after adjusting timing ( with known factory timing marks ) and checking all areas for vacuum leaks.
If I cap the AAR hose the idle is normal and there is adjustment left on the idle screw.
The points plate moves freely with vacuum in both directions.
TIA
post Sep 24 2013, 09:08 AM
Remove it and as Rich said PB it or WD40 it. Placing it in the freezer for an hour then apply 12V. Repeat until it fully opens & closes. It will operate w/o power but takes longer to seal off when engine heat is it's only source.
- Lo-Fi Version Time is now: 2nd April 2026 - 07:02 AM
