> AEM Air Fuel Gauge- Awesome!, Innovate sucks!!!!
tornik550
post Jul 10 2013, 08:04 PM
For the past year, I have been fighting my innovate lc1 setup. It would work under certain circumstances. I never really trusted the readings. Everything was setup properly and calibrated properly. I just got fed up and got an AEM setup. Installed it, started right up. Turns out that my innovate readings were really inaccurate. I was having a super difficult time tuning my carbs cause I was getting strange readings. Now with the AEM, it turns out that my carbs are pretty close to where they should be (IMG:style_emoticons/default/headbang.gif)
Very please with the AEM setup.
Justinp71
post Sep 23 2013, 08:42 PM
Is the AEM cable long enough? Sounds like everyone just runs it under the motor, into the cable tunnel and up the front firewall? Does anyone know if its long enough to do the drivers side pillar gauge pod?
worn
post Sep 24 2013, 11:39 AM
can't remember
QUOTE(Justinp71 @ Sep 23 2013, 06:42 PM) *
I had a lot of extra wire running up the front fire wall and then back to a floor mount (which is a bad spot). I ran up the firewall for eventual mounting up with the other gauges. You should be fine.
tornik550   AEM Air Fuel Gauge- Awesome!   Jul 10 2013, 08:04 PM
Trekkor   Same one I use. Nice set-up. KT   Jul 10 2013, 08:11 PM
brant   I've checked my innovate system with an air in...   Jul 10 2013, 11:48 PM
jim_hoyland   What is AEM ? Have a link ? :)   Jul 11 2013, 07:03 AM
tornik550   What is AEM ? Have a link ? :) http://www.aeme...   Jul 11 2013, 07:06 AM
Mark Henry   How did you mount it? Was the harness long enough?   Jul 11 2013, 07:16 AM
tornik550   How did you mount it? Was the harness long enough...   Jul 11 2013, 07:54 AM
Mark Henry   How did you mount it? Was the harness long enoug...   Jul 11 2013, 11:00 AM
worn   [quote name='tornik550' post='1893468' date='Jul ...   Jul 11 2013, 11:12 AM
worn   How did you mount it? Was the harness long enough...   Jul 11 2013, 10:06 AM
iamchappy   I may have to convert my LC-1 has been acting up..   Jul 11 2013, 07:36 AM
Mark Henry   Sorry I did get a reply from PLX... just was hard ...   Jul 11 2013, 11:04 AM
tornik550   I have a plate in the dash where the radio goes. ...   Jul 11 2013, 11:17 AM
iamchappy   I removed the sensor today, cleaned it up and blew...   Jul 11 2013, 11:56 AM
worn   I removed the sensor today, cleaned it up and ble...   Jul 11 2013, 12:58 PM
Mark Henry   I removed the sensor today, cleaned it up and ble...   Jul 11 2013, 01:12 PM
tornik550   I just received a response from AEM about splicing...   Jul 11 2013, 03:22 PM
Justinp71   Its been a couple months, any updates? I like the...   Sep 23 2013, 07:54 PM
tornik550   Its been a couple months, any updates? I like th...   Sep 23 2013, 08:23 PM
DBCooper   I had an Innovate LC1 that crapped out after a mon...   Sep 23 2013, 08:32 PM
Justinp71   Is the AEM cable long enough? Sounds like everyone...   Sep 23 2013, 08:42 PM
tornik550   Is the AEM cable long enough? Sounds like everyon...   Sep 23 2013, 08:52 PM
worn   Is the AEM cable long enough? Sounds like everyon...   Sep 24 2013, 11:39 AM
Justinp71   Got the gauge yesterday, install time... :smash: ...   Sep 28 2013, 08:41 AM
Justinp71   Got it in, just realized there is a nice hole in t...   Sep 29 2013, 05:43 PM
GeorgeRud   What size is the gauge (2 1/8")? Does it fit...   Sep 30 2013, 09:09 AM
Java2570   It's 52mm (2 1/16") so it's a pretty ...   Sep 30 2013, 10:56 AM
- Lo-Fi Version Time is now: 16th June 2024 - 09:42 PM
