> TACH/SPEED ?
spare time toys
post Jul 21 2004, 07:51 PM
hooked on grilling food.
What is the speed for all gears at about 2100 rpm. I dont have a working speedometer and need to know approx mph. I have a stock side shifter I know tire size will change it a little but just need a close number.
john rogers
post Jul 21 2004, 08:36 PM
If you check over at the Pelican site and download my "Gears" program it will let you enter the gear ratio for each gear, the final drive ratio and tire size (dia, circumference or # turns per mile) and a slider shows the speed vs RPM for each gear. Does a print out too and it is handy to let you see what changing things will do. There are several spreadsheets around but they figure the tire size is set. You could borrow a GPS unit as mine is VERY accurate. Good luck
- Lo-Fi Version Time is now: 11th July 2025 - 03:25 AM
