> bleeding brakes, etc, (title revised)
jimkelly
post Sep 27 2013, 10:50 AM
Delaware USA
I am trying to bleed my bone dry brake system with a MOTIVE pressure system and a mix of long tube, but since they say you can't use SPEED BLEEDERS with MOTIVE, I want to make sure I am not chasing my tail.
I did bleed each corners twice so far and have some small amount of peddle, maybe 25% or so of normal.
the picture below is a new bleeder and one I pulled out of my jack standed car.
shuie
post Sep 27 2013, 12:35 PM
I've been fighting with the same issue for the last 3 days. I had no idea you couldn't use the speedbleeders with the Motive. That's how I used to bleed the brakes on my 911. I thought it was about the only way to do it without an extra person. I guess Im going back to the standard bleeders screws.
jimkelly
post Sep 27 2013, 12:49 PM
Delaware USA
I do not see why they can't be used together, unless, the speed bleeders, need more than the motive's 15-20 psi produces, to open??
the problem I am having now, is that I have some peddle resistance, not much, but using the motive, tons of fluid comes out but very little bubbles.
thus I will try the 2 person technique next.
jim
QUOTE(shuie @ Sep 27 2013, 11:35 AM) *
jimkelly   bleeding brakes, etc   Sep 27 2013, 10:50 AM
Black22   I'm no expert, but those don't look like S...   Sep 27 2013, 11:00 AM
stugray   You should be able to blow both ways through a nor...   Sep 27 2013, 11:07 AM
URY914   Did you google speedbleeders for a picture?   Sep 27 2013, 11:26 AM
jimkelly   I tried youtube. found this in google images but...   Sep 27 2013, 11:35 AM
wndsnd   These are speed bleeders Jim, I took them out cau...   Sep 27 2013, 11:35 AM
jimkelly   thanks for the pic : )   Sep 27 2013, 11:49 AM
jimkelly   think I will try the two person - old school style...   Sep 27 2013, 11:55 AM
shuie   I've been fighting with the same issue for the...   Sep 27 2013, 12:35 PM
jimkelly   I do not see why they can't be used together, ...   Sep 27 2013, 12:49 PM
Elliot Cannon   I've used speed bleeders all the time. Mostly...   Sep 27 2013, 12:42 PM
jimkelly   oh, and, it seems all the bleeders I have, long an...   Sep 27 2013, 12:51 PM
URY914   I bleed the rears by myself. Use a long stick and ...   Sep 27 2013, 12:53 PM
andys   For a one-man operation, pressure bleeding or reve...   Sep 27 2013, 01:31 PM
SLITS   I use a Hospital Aspirator (vacuum pump). One thi...   Sep 27 2013, 01:54 PM
r_towle   bone dry system wont bleed unless you bench bleed ...   Sep 27 2013, 02:03 PM
jimkelly   I did crack the hard lines to the MC, but only for...   Sep 27 2013, 02:21 PM
r_towle   I did crack the hard lines to the MC, but only fo...   Sep 27 2013, 02:24 PM
jimkelly   to be certain - we are talking about cracking thes...   Sep 27 2013, 02:31 PM
shuie   yep, I've got the same issue. Lots of fluid an...   Sep 27 2013, 02:45 PM
jimkelly   this is where I saw it mentioned - the warning. h...   Sep 27 2013, 02:51 PM
jimkelly   well, looks like it is time to tackle vent clearan...   Sep 28 2013, 08:53 AM
jimkelly   so when adjusting the inner on a car, this is the ...   Sep 28 2013, 09:10 AM
jimkelly   well, i can get some peddle, but some times peddle...   Sep 28 2013, 01:58 PM
- Lo-Fi Version Time is now: 12th August 2026 - 05:02 AM
