> bleeding brakes, etc, (title revised)
jimkelly
post Sep 27 2013, 10:50 AM
Delaware USA
I am trying to bleed my bone dry brake system with a MOTIVE pressure system and a mix of long tube, but since they say you can't use SPEED BLEEDERS with MOTIVE, I want to make sure I am not chasing my tail.
I did bleed each corners twice so far and have some small amount of peddle, maybe 25% or so of normal.
the picture below is a new bleeder and one I pulled out of my jack standed car.
shuie
post Sep 27 2013, 02:45 PM
yep, I've got the same issue. Lots of fluid and really no bubbles. I've tried gravity bleeding with one end of the car in the air. Tried the Archimedes' Principle trick with lines strung up in the air above the reservoir and bleeders open. Tried the plumbers putty trick around the bleeders to make sure they are not sucking air into the brake circuit when open. I get a decent pedal if I pump the brakes lightly after the circuit pressurized by the Motive. It's almost like air in the MC gets pushed out, but as soon as I depressurize the Motive I have no pedal again. I'll try the MC fitting drip trick next.
I've never been able to bench bleed a MC without spilling all of the brake fluid out of it on the install before getting the feed lines snapped in place. I have no idea how people are able to do that while crawling under the car. I've never had any issues bleeding brakes with the Motive & speedbleeders before.
jimkelly   bleeding brakes, etc   Sep 27 2013, 10:50 AM
Black22   I'm no expert, but those don't look like S...   Sep 27 2013, 11:00 AM
stugray   You should be able to blow both ways through a nor...   Sep 27 2013, 11:07 AM
URY914   Did you google speedbleeders for a picture?   Sep 27 2013, 11:26 AM
jimkelly   I tried youtube. found this in google images but...   Sep 27 2013, 11:35 AM
wndsnd   These are speed bleeders Jim, I took them out cau...   Sep 27 2013, 11:35 AM
jimkelly   thanks for the pic : )   Sep 27 2013, 11:49 AM
jimkelly   think I will try the two person - old school style...   Sep 27 2013, 11:55 AM
shuie   I've been fighting with the same issue for the...   Sep 27 2013, 12:35 PM
jimkelly   I do not see why they can't be used together, ...   Sep 27 2013, 12:49 PM
Elliot Cannon   I've used speed bleeders all the time. Mostly...   Sep 27 2013, 12:42 PM
jimkelly   oh, and, it seems all the bleeders I have, long an...   Sep 27 2013, 12:51 PM
URY914   I bleed the rears by myself. Use a long stick and ...   Sep 27 2013, 12:53 PM
andys   For a one-man operation, pressure bleeding or reve...   Sep 27 2013, 01:31 PM
SLITS   I use a Hospital Aspirator (vacuum pump). One thi...   Sep 27 2013, 01:54 PM
r_towle   bone dry system wont bleed unless you bench bleed ...   Sep 27 2013, 02:03 PM
jimkelly   I did crack the hard lines to the MC, but only for...   Sep 27 2013, 02:21 PM
r_towle   I did crack the hard lines to the MC, but only fo...   Sep 27 2013, 02:24 PM
jimkelly   to be certain - we are talking about cracking thes...   Sep 27 2013, 02:31 PM
shuie   yep, I've got the same issue. Lots of fluid an...   Sep 27 2013, 02:45 PM
jimkelly   this is where I saw it mentioned - the warning. h...   Sep 27 2013, 02:51 PM
jimkelly   well, looks like it is time to tackle vent clearan...   Sep 28 2013, 08:53 AM
jimkelly   so when adjusting the inner on a car, this is the ...   Sep 28 2013, 09:10 AM
jimkelly   well, i can get some peddle, but some times peddle...   Sep 28 2013, 01:58 PM
- Lo-Fi Version Time is now: 12th August 2026 - 05:02 AM
