| jimkelly |
Sep 27 2013, 10:50 AM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
I am trying to bleed my bone dry brake system with a MOTIVE pressure system and a mix of long tube, but since they say you can't use SPEED BLEEDERS with MOTIVE, I want to make sure I am not chasing my tail.
I did bleed each corners twice so far and have some small amount of peddle, maybe 25% or so of normal. the picture below is a new bleeder and one I pulled out of my jack standed car. Attached thumbnail(s) |
| jimkelly |
Sep 28 2013, 09:10 AM
so when adjusting the inner on a car, this is the thing that needs to be turned to adjust inner clearance?
(IMG:http://www.914world.com/bbs2/uploads/post-1110-1228605544.jpg) |
jimkelly bleeding brakes, etc Sep 27 2013, 10:50 AM
Black22 I'm no expert, but those don't look like S... Sep 27 2013, 11:00 AM
stugray You should be able to blow both ways through a nor... Sep 27 2013, 11:07 AM
URY914 Did you google speedbleeders for a picture? Sep 27 2013, 11:26 AM
jimkelly I tried youtube.
found this in google images
but... Sep 27 2013, 11:35 AM
wndsnd These are speed bleeders Jim,
I took them out cau... Sep 27 2013, 11:35 AM
jimkelly thanks for the pic : ) Sep 27 2013, 11:49 AM
jimkelly think I will try the two person - old school style... Sep 27 2013, 11:55 AM
shuie I've been fighting with the same issue for the... Sep 27 2013, 12:35 PM
jimkelly I do not see why they can't be used together, ... Sep 27 2013, 12:49 PM
Elliot Cannon I've used speed bleeders all the time. Mostly... Sep 27 2013, 12:42 PM
jimkelly oh, and, it seems all the bleeders I have, long an... Sep 27 2013, 12:51 PM
URY914 I bleed the rears by myself. Use a long stick and ... Sep 27 2013, 12:53 PM
andys For a one-man operation, pressure bleeding or reve... Sep 27 2013, 01:31 PM
SLITS I use a Hospital Aspirator (vacuum pump).
One thi... Sep 27 2013, 01:54 PM
r_towle bone dry system wont bleed unless you bench bleed ... Sep 27 2013, 02:03 PM
jimkelly I did crack the hard lines to the MC, but only for... Sep 27 2013, 02:21 PM
r_towle
I did crack the hard lines to the MC, but only fo... Sep 27 2013, 02:24 PM
jimkelly to be certain - we are talking about cracking thes... Sep 27 2013, 02:31 PM
shuie yep, I've got the same issue. Lots of fluid an... Sep 27 2013, 02:45 PM
jimkelly this is where I saw it mentioned - the warning.
h... Sep 27 2013, 02:51 PM
jimkelly well, looks like it is time to tackle vent clearan... Sep 28 2013, 08:53 AM
jimkelly well, i can get some peddle, but some times peddle... Sep 28 2013, 01:58 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th August 2026 - 05:03 AM |
