1972 914 crank no start |
Number47 |
Sep 29 2013, 03:25 PM
Newbie Group: Members Posts: 3 Joined: 29-September 13 From: Kalamazoo Michigan Member No.: 16,454 Region Association: Upper MidWest |
ok here goes. i have been enlisted to help a friend that has little automotive background get his 72 914 running after a 5+ years in storage. this far i have pumped the gas tank empty and filled with fresh. the fuel pump runs till it builds pressure then stops running. i have spark into the dist. cap but no spark out. cap and rotor were new when parked. now the rotor is nothing like i have ever seen before. i have very limited experience with american muscle and im a diesel mechanic for a living so this whole extra ignition system is borderline voodoo to me. i cant seem to get this sob to run and im bound and determine to do so. so if anyone can tell me what i need to look for that would be great. also i need to know the location of the fuel pump and fuel filter(havent looked yet but figured im on here ill ask anyway). thanks for any help and if more info is needed let me know and ill get it promptly as possible. vin will be here soon
Mike Bellis |
Sep 29 2013, 06:14 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
If you have spark to the distributor, you should have spark to the plugs unless your cap or rotor are bad. |
Lo-Fi Version | Time is now: 10th June 2024 - 11:01 PM |
