QUOTE(rhodyguy @ Nov 11 2013, 08:12 AM)
carbs or fi? in addition to the filter there is a fine mesh sock/stainer located in the bottom of the fuel tank. it can be seen when the tank is emptied of fuel by looking down the tank fill opening and may get sucked flat restricting fuel flow. the reg filter should be below the engine shelve roughly where the battery sits unless the pump has been relocated. have your friend get a Haynes 914 manual.
if the pump had been relocated which i dont think think it has where is the updated location. if i read correctly the old location is down under the car on the right side just ahead of where you say the fuel filter should be. he wont get a manual because he trying to sell it
