> to seam seal and under coat or not
mrbubblehead
post Sep 29 2013, 08:06 PM
Twodollardoug
it would be nice if we had a paint and body forum in our beloved 914world to ask these kind of questions ...
i have spent months and months scraping seam sealer and under coating and sand blasting rust and alot of welding. i then put a coat of rustolium primer to temporarily protect the bare steel until all of my metal work is finished. then plan to blast off the rustolium one section at a time and shoot an epoxy primer over the bare steel.
now my question to you paint and body gurus. is it necessary to re-seam seal the seams?
it was such a pain staking task removing every spec of seam sealer (at times with a dental pick) i hate to apply anything that caused so much rust in the first place. im glad i took the time to strip the original sealer out of there. because even though it looked in tact and in good condition i would find rust underneath it. now im sure it will be rust free.
if i do need to reaply the seam sealer, when do i do it? to the bare blasted metal? after the epoxy primer? what type of seam sealer should i use? i really dont want to have to buy the special wurth gun. the original sealer look is of no concern to me.
as far as undercoating, if it is necessary i thought about taking the tub dowm to have the bottom and fender wells rhino lined but i hate adding any unnecessary weight.
this car will be driven alot if not daily except for rainy days.
any thoughts
tia
PanelBilly
post Sep 29 2013, 09:44 PM
And the bed liners are very light. If your looking for the lightest car for a race, it does add weight, but modern bed liner is engineered to add as little weight as possible. Check out my build and see kevlar undercoat
- Lo-Fi Version Time is now: 2nd April 2026 - 10:41 AM
