MrHyde |
Senior Member ![]() ![]() ![]() Group: Members Posts: 525 Joined: 13-October 10 From: Ontario, Canada Member No.: 12,268 Region Association: None ![]() |
I have a couple gremlins I'm trying to sort out and thought I would post it up here...
Most of everything is working just fine, headlights/motors are working much better than they did in the parts car. I imagine thats because theres actual metal around the ground points.. (IMG:style_emoticons/default/biggrin.gif) Anyways heres what I got 1: Turn signals.. with headlights off left and right turn signals work just fine as do the 4-ways. With headlights on only the left turn signal works. right does nothing. no click, nothing. 2: trunk light and license plate lights are getting no power. This is coming off of fuse 7 along with the gauge lights which are working just fine and dimming when the knob is turned. I think this one might be a simple wire broken but I'm not sure yet. All I know is that I have no power when checked at the trunk light and ground.. |
MrHyde |
Turn signals fixed. (IMG:style_emoticons/default/biggrin.gif)
I went around the car and double checked the ground points. and everything was clean and tight. So I started pulling the light bulbs and checking the sockets for corrosion and loose wires at the lamps. I found two things. 1: The right side turn signal was only a single filiment bulb when it should be a double. Changed the bulb and bingo, the signals work when the headlights/parking lights are on. 2: I also noticed that the brake/marker lights in the back were flashing (dimly) along with the left turn signal. Also the front left marker light was flashing and it shouldn't be. turns out I was looking at the tail lamp upside down or something when I hooked it up and had the ground and one other wire switched. switched them back and all is good now. Now I'm working on running a new line for the trunk light/license plate lights. The wire itself is broken/frayed near the trunk light. |
Lo-Fi Version | Time is now: 8th July 2025 - 09:23 PM |
