nine9three |
Member ![]() ![]() Group: Members Posts: 142 Joined: 29-December 11 From: Oregon Member No.: 13,946 Region Association: Pacific Northwest ![]() |
I just recently replaced all of the hoses on the AC system and after replacing the wiring to the relay (above center console on interior evap) doesn't work. The bowlsby DPD diagram is different than mine (relay). Could some one provide a photo with captions on photo relating to where the wiring connections go from relay?
Thanks |
nine9three |
Mike,
Yikes, they are all the same color. Can you identify where the wires are coming from? The far right wire (near side) with yellow terminal end I believe goes to the ON/Off switch to the unit. The center two wires go to the fuse panel. Can you identify which terminals (1-12)? The bottom far end goes ?? and the top twisted pair?? My wires are different colors so this makes it much tougher. Thanks in advance |
Lo-Fi Version | Time is now: 10th June 2024 - 12:05 PM |
