MrHyde |
Senior Member ![]() ![]() ![]() Group: Members Posts: 525 Joined: 13-October 10 From: Ontario, Canada Member No.: 12,268 Region Association: None ![]() |
got a couple issues I could use some advice on. 2316cc with weber 44's
1: CHT i gave a micro1000 CHT gauge.. its not reading anything.. i have it under #3 cylinder and its connected to the extension line and heat shrinked and on the gauge its red to + and purple to - . this is the only way it will go as one is a male and the other is a female connector. 2: carbs are running lop sided. right bank is pulling about 5 and the left side is pulling 12-14. this is with the idle speed screws backed right off. Any adjustments on the right banks mixture screws do pretty well nothing until closed and then is sputters a bit. Adjusting the mixture screws on the left side start making changes to the idle and sound of th engine immediately.. 3: voltage gauge is not reading anything but the idiot light does go out once the motor is running 4: fuel gauge and the temp gauge ( in combo gauge) are both pegged.. I think this is most likely ground. i'll check that in a min. I only put a couple gallons of gas in the tank. side note.. once motor was warmed up doing cam break in the oil pressure was steady at a hair over 20psi andi only have one small drip of oil on one valve cover, which i'll look at when i do a valve adjustment. |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
My first guess.
I've never used the Tangerine linkage, so though I have a good idea I don't really know how it works. I usually toss the hexbar linkage and build my own center pull much like CSP sells. On higher end jobs and my own cars I've built linkages since the 90's. It's quite a job to have perfect sync and I use better quality balljoints (linkage ends). Most coughing through the carb , unbalance, is sync issues. Number two Get rebuild kits and clean those freakin' things, all it takes is a hair of lint to fuck with your head. Number three is a vacuum leak Number four is jetting, do you have a wideband O2 meter on that puppy? If not I'll shoot my set-up over to you, no charge but you cover shipping both ways and you know you are responsible for damage. It has a brand new lambda. Number 5 is check the fuel enrichment circuit , it's the lever thingy on the side of the carb (it may now have a block off plate), there are two plungers inside and they must be seated all the way down. In the past I have tapped them for a grub screw and permanently disabled them. |
Lo-Fi Version | Time is now: 1st July 2025 - 06:57 AM |
