> need help with a couple issues with motor startup
MrHyde
post Oct 8 2013, 10:47 AM
got a couple issues I could use some advice on. 2316cc with weber 44's
1: CHT i gave a micro1000 CHT gauge.. its not reading anything.. i have it under #3 cylinder and its connected to the extension line and heat shrinked and on the gauge its red to + and purple to - . this is the only way it will go as one is a male and the other is a female connector.
2: carbs are running lop sided. right bank is pulling about 5 and the left side is pulling 12-14. this is with the idle speed screws backed right off. Any adjustments on the right banks mixture screws do pretty well nothing until closed and then is sputters a bit. Adjusting the mixture screws on the left side start making changes to the idle and sound of th engine immediately..
3: voltage gauge is not reading anything but the idiot light does go out once the motor is running
4: fuel gauge and the temp gauge ( in combo gauge) are both pegged.. I think this is most likely ground. i'll check that in a min. I only put a couple gallons of gas in the tank.
side note.. once motor was warmed up doing cam break in the oil pressure was steady at a hair over 20psi andi only have one small drip of oil on one valve cover, which i'll look at when i do a valve adjustment.
MrHyde
post Oct 13 2013, 07:27 AM
I thinks I'm good for pressure.. it was reading high ( 40-50) just when it was cold ( i changed the oil yesterday when I adjusted the valves). Once it warmed up it was about 15 ish at idle. Now mind you I wasn't checking the pressure gauge that often as I couldn't see it from the engine bay.. How do I go about checking for a vacuum leak?? Obvious guess for me would be to just go around each carb and make sure all screws ( other than the mixture and air bypass) are snug and I don't feel any leaks.
first thing I'll do it completely disconnect the linkage to rule that out.
I was hoping Id get to go for a drive around the block or so with it before putting her away for the winter and I was going to rebuild the carbs then... that may not be possible. :-)
I appreciate the offer for the sideband.. I will take you up on that. But I think i should wait until I get thing stabalized before I start changing jets shouldn't I ??
MrHyde   need help with a couple issues with motor startup   Oct 8 2013, 10:47 AM
ThePaintedMan   First, most important part - oil pressure. What rp...   Oct 8 2013, 11:00 AM
MrHyde   just over 20psi at just over 2000 rpm where I was ...   Oct 8 2013, 11:08 AM
ThePaintedMan   I have the same issue. Do you have the older style...   Oct 8 2013, 12:33 PM
MrHyde   I believe I have early italian webers.. Theres onl...   Oct 8 2013, 01:40 PM
peteyd   got a couple issues I could use some advice on. ...   Oct 9 2013, 06:19 AM
Mblizzard   On the carbs, there are more qualified experts lik...   Oct 9 2013, 07:13 AM
MrHyde   I did not get a chance today to get to work on the...   Oct 9 2013, 01:46 PM
MrHyde   Ok... got the valves adjusted after break in.. co...   Oct 12 2013, 08:15 PM
MrHyde   Pete: I think you're right.. switched the nu...   Oct 12 2013, 08:18 PM
ThePaintedMan   Hmm. So you're saying that you're seeing t...   Oct 12 2013, 08:58 PM
MrHyde   Hmmm. You know what. Maybe I'm going about t...   Oct 12 2013, 11:28 PM
Dave_Darling   I'm not much of a carb guy, but I'm seeing...   Oct 13 2013, 12:20 AM
Mark Henry   My first guess. I've never used the Tangerine ...   Oct 13 2013, 06:56 AM
Mark Henry   BTW rule of thumb hot engine 10psi per 1000rpm is ...   Oct 13 2013, 07:01 AM
Mark Henry   Mike I'm home if you want to call me, but my c...   Oct 13 2013, 07:21 AM
MrHyde   I thinks I'm good for pressure.. it was readin...   Oct 13 2013, 07:27 AM
ThePaintedMan   Lots of good stuff from Dave and Mark. Checking fo...   Oct 13 2013, 08:12 AM
Joe Sharp   I use a squirt gun with water in it to check for v...   Oct 13 2013, 08:24 AM
MrHyde   Just to add a bit more info.. I'm out in the g...   Oct 13 2013, 12:24 PM
MrHyde   GOT IT !!!! Video to follow aft...   Oct 13 2013, 04:42 PM
ThePaintedMan   :Qarl: :popcorn:   Oct 13 2013, 05:06 PM
MrHyde   Took her for a drive around the block and to the g...   Oct 13 2013, 08:04 PM
MrHyde   It was the carb syncing... I'm sure I had the ...   Oct 13 2013, 08:10 PM
- Lo-Fi Version Time is now: 1st July 2025 - 06:11 AM
