MrHyde |
Senior Member ![]() ![]() ![]() Group: Members Posts: 525 Joined: 13-October 10 From: Ontario, Canada Member No.: 12,268 Region Association: None ![]() |
got a couple issues I could use some advice on. 2316cc with weber 44's
1: CHT i gave a micro1000 CHT gauge.. its not reading anything.. i have it under #3 cylinder and its connected to the extension line and heat shrinked and on the gauge its red to + and purple to - . this is the only way it will go as one is a male and the other is a female connector. 2: carbs are running lop sided. right bank is pulling about 5 and the left side is pulling 12-14. this is with the idle speed screws backed right off. Any adjustments on the right banks mixture screws do pretty well nothing until closed and then is sputters a bit. Adjusting the mixture screws on the left side start making changes to the idle and sound of th engine immediately.. 3: voltage gauge is not reading anything but the idiot light does go out once the motor is running 4: fuel gauge and the temp gauge ( in combo gauge) are both pegged.. I think this is most likely ground. i'll check that in a min. I only put a couple gallons of gas in the tank. side note.. once motor was warmed up doing cam break in the oil pressure was steady at a hair over 20psi andi only have one small drip of oil on one valve cover, which i'll look at when i do a valve adjustment. |
JoeSharp |
In Irvine, Ca. May 15-18 ![]() ![]() ![]() ![]() Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States ![]() |
I use a squirt gun with water in it to check for vacuum leaks. I squirt it at the spots that I suspect of leaking. If it is leaking the water will change the way the car is idling. The reason I use water is it is not flammable and when it get sucked into the leak it just plugs it momentarily.
Lo-Fi Version | Time is now: 1st July 2025 - 07:25 AM |
