Changing fuel line (leaks), Not sure if this is coming or going line |
boxsterfan |
Oct 14 2013, 02:12 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
So, some previous owner of my 1974 2.0L had changed one of the fuel lines coming from the firewall to where it goes up through the engine bay/tray. They changed one of the lines to modern 8mm rubber fuel hose.
However, they left one of those lines as the old "cloth" (?) wrapped fuel lines. (IMG:style_emoticons/default/headbang.gif) Well, this morning I smelled gas inthe garage and saw that the old "cloth" line was dripping gas. I couldn't tell if it was leaking at the connection goign up through the engine bay or if just the whole line was "soaked". 1. I put a bucket under where I saw the drips coming from and told the wife to stay away from the car today until I get home. 2. What's the easiest way to get access to this area to change those fuel lines? Remove right rear tire and remove the heater box connection?\ TIA.... |
JawjaPorsche |
Oct 14 2013, 02:35 PM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
Glad you didn't have a fire. Pretty tight under there. Removing heater hose gives you some room. Sorta like building a ship in a bottle! Don't climb under car without jack stands. I use a 8 by 8 board under tire if you can get it that high. Disconnect battery so no spark can occur.
Lo-Fi Version | Time is now: 1st June 2024 - 11:23 PM |
