i lost my 4th gear!!!, where did it go? |
BahnBrenner914 |
Jul 23 2004, 09:19 PM
The girl is gone and all I have now is a beat-up teener Group: Members Posts: 301 Joined: 22-May 04 From: Gig Harbor and University Place, WA :: School in Angola, IN :: girlfriend in Sarasota, FL Member No.: 2,094 Region Association: None |
so i just got my 76 914 running and the valve covers and push rod tube seals replaced so i'm not donating excessive amounts of oil to the road. so i just took her out on the road to test her out. 1st gear is fine. second gear seems to be tough to get. its about 50/50 whether it engages or not. i figured that if i push it a little to one side while shifting in it works better. then i put it in 3rd, not tough, works well. then i rev it up to about 3500rpm (51mph?) and go to shift into 4th. nothing. can't find it anywhere. i already opened up the tranny on this car and the synchos are all fine, nothing completely broken. someone help me before i (IMG:style_emoticons/default/ar15.gif) my 914.
Brad Roberts |
Jul 23 2004, 09:26 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Shift linkage is out of whack. Check all the shift linkage from shifter to tranny. See if any bushings have popped out or happen to be missing completely. If everything appears to be ok.. then you need to pull back the carpet on the center tunnel and adjust the shift rod going into the shifter. It is too far in one direction.
B |
Lo-Fi Version | Time is now: 3rd June 2024 - 01:13 AM |
