supporting car on jackstands for eng removal, how high to raise car for engine removal |
yellowFV |
Jul 23 2004, 08:34 PM
Newbie Group: Members Posts: 33 Joined: 19-July 04 From: Philadelphia, PA Member No.: 2,372 |
I've been supporting the car at the rear with jackstands under the trailing arm mount point at the chassis. This method seems to suit the chinese ratchet type jackstands I have.
To remove the engine where is the best point to support the car from ?... I'm wondering if the round jack points would be better in giving more room around the work area since they are forward out of the way... I was going to have a welder friend make up a set of wide based stands from 2" x 2" heavy tubing with a round pipe peice that mates to the jack point securely.. How high is the optimum height needed for engine removal. ? I did not want to get the engine halfway out and realize it won't clear or something... Rob wellner ps I promise this is the last stupid newbie question I will post... for at least a couple of days or so. |
watsonrx13 |
Jul 24 2004, 08:56 AM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
I agree with Andy, put the jack stands underneath the floor 'doughnut'. I used a 3 ton floor jack to lower the engine, then rolled it out from underneath the car. I did remove the carbs before hand.
Attached image(s) |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:37 PM |
