> 912 + Subaru STi motor +WRX trans project, conversion
RonW
post Feb 16 2013, 04:45 PM
Hey guys, I know its not a 914 but hoping to share info and request help on my project since the 912 board is fairly devoid of these conversions.
car is a '68 912 and last year I installed a 2005 STi Spec-C JDM motor and running the stock ecu and stripped down harness. I used an adapter plate and adapter flywheel and stage 2 Sach pp/clutch.
for exhaust i used a pair of 2 into 1 header stubs that outback makes and brought each bank up to a turbo flange, then exhausted it to Coast Fabrication muffler. used twin turbosmart EWG with a locked out IWG.
on the inlet side, ran it thru the stock MAF thru the turbo to a water/air intercooler and a turbosmart BOV
up front im running a ron davis radiator and a fuel safe fuel cell with the mostly bent tubing run under the car just inboard of the pinch seam, similar to how the factory ran the oil cooler lines and short sections of 1.25" hose connecting.
with the stock ecu ive have the stock tach sent in to North Hollywood Speedo to modify to take the ecu tach signal and redo the face to 8k redline
the rest of the car is set up with 82SC front end and fresh Bilsteins and elephant polybronze bushes all around and lowered ride height.
So that was phase one and been running her for the last 4 months or so. drove from SF area to Santa cruz and if i kept the revs at 3k then got 30 mpg but was only doing like 60 mph. if i increased to 75mph then 3400rpm and 24mpg. so i decided to go down this subaru path yet further and scored and 2010 WRX 5 speed that only had 20k miles on it. I am swapping in a reveres ring and pinion and will utilize 930 adapter flanges.
Problem: one of many come with this swap for a 901 bodied car.
1) 930 axle wont bolt to the short wheel base trailing arms - solution, take later model LWB and have them modified to SWB dimensions by a shop that has a jig for this very mod. this will then allow for clearance and use with those larger stub axle flanges. plus the bonus of bigger brake options - this should be straight forward
2) transaxle mount - modify stock or subaru mount to bolt to the stock location - again wont know til im there
3) shift rod - hoping to mate the stock shift rod and retain the wevo shifter set up but wont know until i get there. i wish i could cable shift like many here have with an MR2 but no room.
THIS IS WHERE I NEED YOUR COLLECTIVE HELP
4) hydraulic slave for clutch - stock is obviously a cable actuated system and i really do not want to try to graft in a Tilton pedal cluster. any recommendations of making this work? ie cable actuation to some type of master to a slave???
any advise would be much appreciated and i hope i'm ok posting my 912 project here.
veekry9
post Oct 21 2013, 08:57 PM
OldMember
Group: Retired Members
912RON
That would be worth seeing on youtube.
I recall there are a number of 914s
that have posted their vids complete with a
selection of their favourite music.
Now a 912 belching tiresmoke and flames
would be a rare thing.
RonW
post Oct 21 2013, 09:29 PM
QUOTE(veekry9 @ Oct 21 2013, 07:57 PM) *
912RON
no belching tire smoke but a vid none the less
not sure if im posting this correctly - thanks Chris H for helping me embed this correctly, i had the entire url, not just the "OsZ4F1cwgeA"
https://www.youtube.com/watch?v=OsZ4F1cwgeA
RonW   912 + Subaru STi motor +WRX trans project   Feb 16 2013, 04:45 PM
RonW   http://www.914world.com/bbs2/uploads_offsite/iwolf...   Feb 16 2013, 04:48 PM
d914   Problem: one of many come with this swap for a 901...   Feb 16 2013, 06:59 PM
a914622   I like your idea of a cable actuated master for th...   Feb 16 2013, 07:17 PM
DBCooper   I have the Tilton pedals in mine, using short M/C...   Feb 16 2013, 08:16 PM
jpnovak   Ron, I used a Honda application for my MC. drill...   Feb 16 2013, 08:39 PM
a914622   The biggest problem I see with this conversion is...   Feb 16 2013, 09:43 PM
RonW   d914: yep, ive seen the video of how the Todd at ...   Feb 17 2013, 12:44 PM
Britain Smith   Looking great Ron!   Feb 18 2013, 02:10 AM
jpnovak   I did not realize that the transmissions were so d...   Feb 18 2013, 09:20 AM
RonW   no worries jamie, im sure we'll hook up again ...   Feb 18 2013, 01:13 PM
RonW   here is the pedal cluster that DBCooper is using t...   Feb 18 2013, 01:50 PM
Britain Smith   Is that the same speed sensor I am using Ron? The...   Feb 19 2013, 12:05 PM
dfelz   Ron, car looks fantastic! About your 5-gauge ...   Feb 19 2013, 12:26 PM
RonW   Is that the same speed sensor I am using Ron? Th...   Feb 19 2013, 07:32 PM
Kraftwerk   Sorry, I can't help but I will say your car lo...   Feb 21 2013, 11:31 PM
RonW   first off, thanks for all the positive comments, m...   Mar 16 2013, 09:35 PM
RonW   Time to start on the TY758 WRX tranny. Here are a...   Jun 9 2013, 03:39 AM
DBCooper   Wow, great work, beautiful car, super fun project....   Jun 9 2013, 05:52 AM
RonW   thank your for the kind words. it is very fun but...   Jun 9 2013, 08:41 AM
oldschool   Ron very cool 912 do have any pictures of the buil...   Jun 9 2013, 01:09 PM
RonW   Thanks oldschool. So, radiator mounted up front a...   Jun 9 2013, 01:34 PM
396   All I can say is WOW, great looking fabs on this c...   Jun 9 2013, 03:48 PM
aircooledtechguy   I don't know how I missed this thread earlier....   Jun 9 2013, 09:41 PM
RonW   Hey Nate, thanks. I have not yet decided on the c...   Jun 9 2013, 11:37 PM
rick 918-S   Nice build. :popcorn:   Jun 10 2013, 08:14 AM
Zaney   Great Build!!! For the clutch option,...   Jun 10 2013, 02:43 PM
RonW   Nate, thanks for link, it yielded a few ideas :) ...   Jun 16 2013, 07:14 PM
veekry9   Nate, thanks for link, it yielded a few ideas :) ...   Oct 21 2013, 08:00 PM
RonW   This is Great Work Ron. Are you the first in the...   Oct 21 2013, 08:49 PM
RonW   long overdue for update: I want to get the trans i...   Oct 19 2013, 09:39 AM
jpnovak   Ron, Just run a Hargett or something similar to r...   Oct 19 2013, 07:09 PM
Dr Evil   Dang. I can see me following this build to a T and...   Oct 21 2013, 12:17 AM
RonW   Jamie, they hargett is bank and from what ive read...   Oct 21 2013, 06:00 PM
veekry9   912RON That would be worth seeing on youtube. I re...   Oct 21 2013, 08:57 PM
RonW   912RON That would be worth seeing on youtube. I r...   Oct 21 2013, 09:29 PM
DBCooper   What I"m really curious to see is the feel yo...   Oct 22 2013, 07:48 AM
veekry9   Thanks Ron That made my day. A lot of questions an...   Oct 22 2013, 07:28 PM
RonW   dbcooper, i am excited to see/feel the results too...   Oct 22 2013, 07:52 PM
veekry9   dbcooper, i am excited to see/feel the results to...   Oct 23 2013, 01:39 PM
Chris H.   Awesome man. Here I'll embed it for you....no...   Oct 23 2013, 01:46 PM
RonW   sounds like a very fun project you have which is a...   Oct 23 2013, 01:57 PM
RonW   thanks Chris H, i wasn't even close. lol i ha...   Oct 23 2013, 02:02 PM
RonW   Received an order of OEM hardware to bolt the flyw...   Nov 15 2013, 07:02 PM
RonW   btw, if anyone is planning on putting a suby in th...   Nov 15 2013, 07:32 PM
RonW   finished up the shifter pedestool, Tilton pedal cl...   Nov 17 2013, 08:17 PM
CptTripps   Man...I keep going back/forth about the Tilton ped...   Nov 18 2013, 08:03 AM
RonW   For reference, I am 5' 9" and medium buil...   Nov 18 2013, 08:56 AM
RonW   Nearly done plumbing and ordered a custom throttle...   Dec 1 2013, 01:26 AM
RonW   been a while lurking and wrenching until i had any...   Apr 19 2014, 08:51 AM
1stworks   Super sick car!!!!!!! ...   Apr 19 2014, 09:27 AM
RonW   Thanks man, lots of fun so far. Starting to ventu...   Apr 19 2014, 10:24 PM
r_towle   Is there a way to NOT hear the blow off valve? A m...   Apr 20 2014, 11:20 AM
RonW   Is there a way to NOT hear the blow off valve? A ...   Apr 20 2014, 12:07 PM
RonW   DBCooper: reporting back and the swap of the maste...   Apr 25 2014, 09:38 PM
DBCooper   DBCooper: reporting back and the swap of the mast...   Apr 26 2014, 03:33 PM
matthepcat   Wow, cool thread. I want one now. Anyone heard fr...   Mar 25 2015, 08:54 AM
RonW   Matt, I'm lurking ;) Thanks for the kind word...   Mar 25 2015, 10:20 AM
matthepcat   Matt, I'm lurking ;) Thanks for the kind wor...   Mar 25 2015, 10:46 PM
oldschool   :Qarl: :Qarl: Wow love this thing....   Apr 30 2016, 04:39 PM
matthepcat   Looks like Ron is selling this now. Wish I could ...   Aug 13 2016, 07:18 PM
RonW   Looks like Ron is selling this now. Wish I could...   Aug 13 2016, 10:03 PM
oldschool   [quote name='matthepcat' post='2384678' date='Aug...   Aug 13 2016, 10:56 PM
RonW   [quote name='matthepcat' post='2384678' date='Au...   Aug 14 2016, 10:12 AM
matthepcat   Doing a 3.6 teener or another tail dragger? [quo...   Aug 14 2016, 12:21 AM
RonW   Doing a 3.6 teener or another tail dragger? [qu...   Aug 14 2016, 10:15 AM
veekry9   A derriere looking blue. :D /   Aug 14 2016, 05:00 PM
- Lo-Fi Version Time is now: 1st August 2025 - 12:03 AM
