reverse light switch connector |
shuie |
Oct 30 2013, 07:33 AM
Member Group: Members Posts: 352 Joined: 17-May 04 From: baton rouge, la Member No.: 2,075 |
Does anyone sell or make the connectors for the reverse light switch on the trans. case? Are the pins for the switch a standard size? I thought I would be able to use some of the leftover pins from my engine wiring harness but those don't fit the switch. Whats the best way to do this? Do I need a different switch, cut up a donor harness?
TIA |
mskala |
Oct 30 2013, 09:25 AM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
Does anyone sell or make the connectors for the reverse light switch on the trans. case? Are the pins for the switch a standard size? I thought I would be able to use some of the leftover pins from my engine wiring harness but those don't fit the switch. Whats the best way to do this? Do I need a different switch, cut up a donor harness? TIA Are you saying you don't have the connectors? If you have them and the wiring is just bad/broken, they can be de-soldered and re-used. They look like the crimp bullet style pieces but they are hollow and have a hole at the end where the wire and solder comes through. De-solder, clean, re-solder. |
Lo-Fi Version | Time is now: 11th June 2024 - 05:05 PM |
