| jimkelly |
Oct 31 2013, 10:38 AM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
my fuel pump also goes on when hazard switch is not pulled but key is turned.
the circuits have got to be connected somehow??? could this be a faulty relay board? or could it be that I put a wire on the wrong spot on the fuse box? my engine is a carbed sbc v8. i'm using the 2 harness wires to power my fuel pump. thanks jim Attached image(s)
| jimkelly |
Oct 31 2013, 05:37 PM
nope, no ecu.
this car ran before, wired like it is. I am thinking to simply wire the fuel pump to a switched positive. though I think my wipers are not working, I need to see if I have a second issue. did this to trick the relay board. http://www.914world.com/bbs2/index.php?showtopic=25954 thanks jim |
jimkelly for some reason, when i pull hazard switch, my fuel pump goes on (flashes on off) Oct 31 2013, 10:38 AM
Dave_Darling Since it isn't stock, the first thing to do is... Oct 31 2013, 10:51 AM
ConeDodger Ha! The old Bumblebee Racer used that as a the... Oct 31 2013, 10:53 AM
Ha! The old Bumblebee Racer used that as a th... Oct 31 2013, 08:16 PM
rhodyguy stock pump harness with new pump end connections? Oct 31 2013, 10:54 AM
jimkelly yes - fuel pump connected to stock harness, like i... Oct 31 2013, 11:00 AM
jimkelly seems my 14 pin plug has power at 12 and 14 pins w... Oct 31 2013, 12:50 PM
Spoke
seems my 14 pin plug has power at 12 and 14 pins ... Oct 31 2013, 09:03 PM
r_towle
seems my 14 pin plug has power at 12 and 14 pins ... Nov 1 2013, 02:47 PM
r_towle go back to the fuse panel and find the black/red s... Oct 31 2013, 01:30 PM
jimkelly there is a black/red wire at the fuse box but it d... Oct 31 2013, 02:25 PM
Dave_Darling Do you even have an ECU? With a carb'ed V8, I... Oct 31 2013, 05:13 PM
HalfMoon I also have a dark one (v-8 converted) and experie... Oct 31 2013, 06:20 PM
Spoke The use of the relay on the relay board to turn th... Oct 31 2013, 07:17 PM
jimkelly nope - pump did not work with coiled wire (which a... Oct 31 2013, 07:42 PM
Spoke nope - pump did not work with coiled wire (which a... Oct 31 2013, 08:09 PM
jimkelly jim: nope - pump did not work with coiled wire (wh... Oct 31 2013, 08:25 PM
Spoke JIM: WITH KEY OFF AND HAZARDS PULLED, LIGHTS BLINK... Oct 31 2013, 08:47 PM
jimkelly I need to figure out which of my 4 relays are for ... Oct 31 2013, 07:18 PM
Spoke
I need to figure out which of my 4 relays are for... Oct 31 2013, 08:01 PM
jimkelly also, do I need the volt regulator (I thought my G... Oct 31 2013, 07:51 PM
Rand . Oct 31 2013, 08:05 PM
jimkelly spoke Q: With key off and flashers on: pin 8 volta... Nov 1 2013, 05:12 AM
Spoke
spoke Q: With key off and flashers on: pin 8 volt... Nov 1 2013, 05:20 AM
jimkelly I have been using a headlight and some long wires ... Nov 1 2013, 07:53 AM
Spoke
I am getting surging power at pin 8 on the 14 pin... Nov 1 2013, 10:30 AM
rhodyguy what happens when you disconnect the flasher relay... Nov 1 2013, 08:29 AM
jimkelly where is flasher relay? is that the one under the... Nov 1 2013, 08:50 AM
rhodyguy looking in aa catalog for the #, not sure of the a... Nov 1 2013, 08:57 AM
rhodyguy and prob feel the click while activated. Nov 1 2013, 10:38 AM
jimkelly I will trace the black wire. I tried to feel clic... Nov 1 2013, 10:50 AM
rhodyguy if you haven't found the hazard system in the ... Nov 1 2013, 11:35 AM
jimkelly but where does it cross over into my fuel pump har... Nov 1 2013, 11:36 AM
jimkelly all 4 relays out - and hazards still work and FP s... Nov 1 2013, 11:42 AM
rhodyguy don't have the computer skills to point to som... Nov 1 2013, 11:47 AM
rhodyguy hot wire the pump? switched fuse (cig lighter?), l... Nov 1 2013, 11:53 AM
jimkelly yes - good eye. I noticed two weak female connecto... Nov 1 2013, 12:04 PM
rhodyguy ok, brown/ground. what does the fuse it goes to co... Nov 1 2013, 12:18 PM
jimkelly the wire went to this fuse. this is the other sid... Nov 1 2013, 12:33 PM
Dave_Darling Brown should never connect to a fuse. Ever.
The ... Nov 1 2013, 12:43 PM
jimkelly thanks dave.
the wire looks very brown in the abo... Nov 1 2013, 01:11 PM
Jeff Bowlsby If I had to guess, you've somehow midwired the... Nov 1 2013, 03:43 PM
jimkelly it makes some sense but so hard to believe.
here ... Nov 1 2013, 04:33 PM
Spoke There is a wire misconnected somewhere. Here's... Nov 1 2013, 05:19 PM
jimkelly something is wrong for sure as my horn and wipers ... Nov 1 2013, 05:36 PM
jimkelly ok, I tried it.
but before I did, due to looking ... Nov 1 2013, 05:48 PM
r_towle This is awesome Jim....sorry for you but it's ... Nov 1 2013, 06:06 PM
jimkelly I feel a little better now.
I am gonna put some g... Nov 1 2013, 06:13 PM
rhodyguy whew…that's a load off huh? good work. Nov 1 2013, 07:14 PM
jimkelly and they say that british cars have wiring issues.... Nov 1 2013, 07:49 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th August 2026 - 05:12 AM |
