| jimkelly |
Sep 16 2013, 12:45 PM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
wiring my v8
and tell me what I have wrong or missing. my bad for never labeling the wires (IMG:style_emoticons/default/headbang.gif) distributor is msd 8360 but you guys are smart (IMG:style_emoticons/default/smoke.gif) and yes - I better connect that oil guage line or I will have a mess on my hands. Attached thumbnail(s) |
| jimkelly |
Nov 4 2013, 07:28 PM
thanks. lots of pics for those few, that may be less capable than myself.
and my pump's manual does address - push fuel. I could issues with driving DOWN steep roads ??? Attached image(s)
jimkelly making some progress on my sbc 307 V8 car Sep 16 2013, 12:45 PM
3d914 IIRC the yellow wire goes to the positive side of ... Sep 16 2013, 01:01 PM
jimkelly thank you - I am editing my collage as we go.
jim Sep 16 2013, 01:05 PM
Spoke Page 5: Red wire from harness is 12V power to coil... Sep 16 2013, 02:13 PM
jimkelly spoke
I am pretty sure my ignition switch was par... Sep 16 2013, 02:30 PM
jmmotorsports
spoke
I am pretty sure my ignition switch was pa... Sep 17 2013, 04:15 AM
chads74
spoke
I am pretty sure my ignition switch was p... Sep 17 2013, 06:19 AM
jimkelly spoke
image 6 - the blue wire loops around and co... Sep 16 2013, 07:31 PM
Spoke
spoke
image 6 - the blue wire loops around and c... Sep 17 2013, 06:49 AM
dwillouby I dont use the relay board. You need a switched 12... Sep 17 2013, 06:42 AM
jimkelly I was thinking that since it seems to be the only ... Sep 17 2013, 07:03 AM
jimkelly finally going to put my crimper and heat shrink to... Sep 17 2013, 08:01 AM
jimkelly starter, shift linkage, gear oil, coolant fill nec... Sep 20 2013, 12:45 PM
76-914 Jim, are you doing this and the Suby conversion or... Sep 20 2013, 02:19 PM
jimkelly I simply want to get the 1972 V8 running and funct... Sep 20 2013, 03:24 PM
jimkelly just goofing around, since I already have a bar th... Sep 21 2013, 08:34 AM
zambezi yes they grind better and produce less heat. Easi... Sep 21 2013, 12:31 PM
jimkelly engine bay shift rod done : )
40.75"
it is ... Sep 21 2013, 01:15 PM
jimkelly some random pics Sep 22 2013, 11:22 AM
kg6dxn Your lower spring perch is upside down... :(
http... Sep 22 2013, 07:17 PM
jimkelly thanks for that!!!
jim Sep 22 2013, 07:45 PM
jimkelly don't be an idiot like me.
anyway, one flippe... Sep 23 2013, 07:41 AM
76-914 Is that a "red" ground wire? <_< Sep 23 2013, 03:04 PM
jimkelly from the relay board to the body? yes. I will ch... Sep 25 2013, 09:27 AM
jimkelly also - before, I had the pos from alt running to p... Sep 25 2013, 09:35 AM
kg6dxn
also - before, I had the pos from alt running to ... Sep 25 2013, 09:01 PM
jimkelly mike - I will get those wires buttoned up - thanks... Sep 26 2013, 09:34 AM
jimkelly guess i'll run the coolant lines today. the 2... Sep 29 2013, 08:25 AM
jimkelly well, not sure I like the relatively short 90 degr... Sep 29 2013, 03:14 PM
bulitt I may have to get one of those 90's. Sep 29 2013, 06:33 PM
jimkelly since the only electrical connector I have, that h... Sep 30 2013, 07:32 AM
jimkelly rcvd the 90 degree tube today - looks good. Oct 2 2013, 09:18 AM
andys Much nicer with that aluminum 90!
Andys Oct 2 2013, 09:26 AM
speed metal army Hey Jim, weather pack electrical connectors are a ... Oct 2 2013, 10:05 PM
jimkelly well, my car had a big gap, at top, between the dr... Oct 7 2013, 11:41 AM
JRust Yeah the aluminum 90% was a good move. I didn... Oct 7 2013, 08:11 PM
jimkelly well two issues.
I need to either come up with a ... Oct 9 2013, 01:12 PM
JRust The big washer with the groove goes on the bottom ... Oct 9 2013, 03:17 PM
jimkelly I have been searching and have yet to find a pic o... Oct 9 2013, 04:57 PM
JRust
I have been searching and have yet to find a pic ... Oct 10 2013, 07:20 AM
jimkelly instead of this jumble of parts, I am thinking of ... Oct 10 2013, 06:29 AM
bulitt I'm thinking you will break your trans ears of... Oct 10 2013, 06:50 AM
jimkelly for engine mounts, found washers that fit perfectl... Oct 10 2013, 07:34 AM
Chris H. Hijack but this exhaust setup is AWESOME
That... Oct 10 2013, 09:43 AM
jimkelly good point. behind trans is where the most space ... Oct 10 2013, 09:51 AM
mittelmotor I like the 2-in/2-out approach as well. Keeps the ... Oct 10 2013, 01:22 PM
jimkelly well, finally got a battery today. hooked it up, ... Oct 10 2013, 01:41 PM
jimkelly hooked my fuel to gas but she backfires and pops. ... Oct 11 2013, 07:24 AM
wndsrfr
hooked my fuel to gas but she backfires and pops.... Oct 11 2013, 07:53 AM
DBCooper
or is this round mark at top of flywheel the tdc ... Oct 11 2013, 09:51 AM
jimkelly firing order seems to be 18436572
but finding tdc ... Oct 11 2013, 08:22 AM
jimkelly thanks guys, you've given me good guidance. dt... Oct 11 2013, 10:36 AM
tooms351 Run a wire with allegator clips from starter selen... Oct 11 2013, 04:40 PM
jimkelly I basically have the with my console - but will tr... Oct 11 2013, 05:52 PM
DBCooper It looks like the number 1 wire goes up to the lef... Oct 11 2013, 04:42 PM
jimkelly all the images i found have cylinders
1-2
3-4
5-6... Oct 11 2013, 05:24 PM
jimkelly db I could kiss you, right on the mouth. GREAT eye... Oct 11 2013, 06:09 PM
Chris H.
Note ... Oct 12 2013, 12:02 PM
jimkelly attached my throttle bracket and throttle cable, a... Oct 14 2013, 08:55 AM
jimkelly set back. fuse box was in contact with block and ... Oct 16 2013, 02:10 PM
Chris H. Whew you dodged a bullet on that one Jim. Check J... Oct 16 2013, 06:35 PM
jimkelly I neglected the first rule - disconnect battery wh... Oct 16 2013, 06:49 PM
bulitt
I neglected the first rule - disconnect battery w... Oct 18 2013, 04:22 PM
jimkelly I thought I may have fried my coil or dist but tha... Oct 18 2013, 04:02 PM
jimkelly price is right.
once this Bacardi wears off, I ca... Oct 18 2013, 04:28 PM
jimkelly yesterday...
filled cooling system with water, spl... Oct 21 2013, 01:32 PM
jimkelly plumbed to carb from firewall, pump and filter.
n... Oct 24 2013, 11:06 AM
jimkelly next to install fuel tank and plug the return line... Oct 24 2013, 03:13 PM
jimkelly got my fuel tank in and fuel pump wired. I need to... Oct 25 2013, 01:31 PM
rhodyguy did you use the jumper wire from the engine relay ... Oct 26 2013, 07:48 AM
jimkelly yes - like this.
http://www.914world.com/bbs2/upl... Oct 26 2013, 07:52 AM
kg6dxn
yes - like this.
As I ponder your symptoms... D... Oct 27 2013, 08:26 PM
rhodyguy the only way to go and still utilize the stock cir... Oct 26 2013, 07:55 AM
jimkelly I could have sworn my car started from key with th... Oct 27 2013, 07:16 AM
Spoke
I still have 2 gremlins, drivers side parking lig... Oct 27 2013, 08:01 AM
jimkelly I will check. I assume you mean both filaments in... Oct 27 2013, 08:36 AM
jimkelly now I am seeing problems everywhere. I pulled a t... Oct 27 2013, 08:29 AM
jimkelly spoke - just tested your directionals rewiring - w... Oct 27 2013, 09:11 AM
jimkelly well - later tach won't do.
it only has one g... Oct 27 2013, 11:21 AM
Spoke Yeah, I didn't like the later tach because of ... Oct 27 2013, 02:53 PM
jimkelly pretty sure its plastic - but I will put it back i... Oct 27 2013, 03:44 PM
jimkelly been off on a tangent with - spoke, dave darling, ... Nov 2 2013, 08:53 AM
jimkelly ok - she started off the ign key and ran for some ... Nov 2 2013, 09:08 AM
kg6dxn You should mount the fuel pump in the front of the... Nov 2 2013, 09:36 AM
rhodyguy rotary pump? if you don't want to do the front... Nov 2 2013, 11:46 AM
jimkelly I checked for a clog or other issue, gas all over ... Nov 2 2013, 02:46 PM
bulitt Obvious Question Jim- do you have gas in the tank? Nov 2 2013, 07:47 PM
jimkelly yes - about 3 gallons - and it spills out if I dis... Nov 3 2013, 06:29 AM
jimkelly dropped ground, but still no good.
put car back o... Nov 4 2013, 01:23 PM
mittelmotor Nice progress. I've heard the pumps are much b... Nov 4 2013, 05:17 PM
Mike Bellis The Permatex sealant is the best one I've ever... Nov 4 2013, 08:00 PM
DBCooper I've used that stuff since I was a kid. Never... Nov 5 2013, 08:53 AM
jimkelly thanks guys for the comments on the permatex produ... Nov 5 2013, 01:15 PM
jimkelly pump in but will probably relocate fuel filter fur... Nov 7 2013, 11:26 AM
rhodyguy filter pior to the pump? Nov 7 2013, 11:28 AM
jimkelly its after pump. when I had pump higher, I had it ... Nov 7 2013, 11:36 AM
jimkelly i had temporarily removed my rear sway bar so I ca... Nov 8 2013, 12:18 PM
Mike Bellis From the pics, that looks like a very bad pump loc... Nov 8 2013, 08:29 PM
jimkelly I too have smashed my share of hose straps but did... Nov 8 2013, 08:40 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th August 2026 - 04:37 AM |
