> making some progress on my sbc 307 V8 car, -- rear sway bar back in
jimkelly
post Sep 16 2013, 12:45 PM
Delaware USA
wiring my v8
and tell me what I have wrong or missing.
my bad for never labeling the wires (IMG:style_emoticons/default/headbang.gif)
distributor is msd 8360
but you guys are smart (IMG:style_emoticons/default/smoke.gif)
and yes - I better connect that oil guage line or I will have a mess on my hands.
DBCooper
post Nov 5 2013, 08:53 AM
14's in the 13's with ATTITUDE
I've used that stuff since I was a kid. Never had any reason to change, so I was curious to see what answers you got, since I've never really had anything else to compare it to. I'd just add don't use too much on threads, you aren't gluing anything together, you're just putting in enough to fill gaps when it tightens. A thin smear is plenty.
Mike, you changed your name. And I can pronounce it now.
jimkelly   making some progress on my sbc 307 V8 car   Sep 16 2013, 12:45 PM
3d914   IIRC the yellow wire goes to the positive side of ...   Sep 16 2013, 01:01 PM
jimkelly   thank you - I am editing my collage as we go. jim   Sep 16 2013, 01:05 PM
Spoke   Page 5: Red wire from harness is 12V power to coil...   Sep 16 2013, 02:13 PM
jimkelly   spoke I am pretty sure my ignition switch was par...   Sep 16 2013, 02:30 PM
jmmotorsports   spoke I am pretty sure my ignition switch was pa...   Sep 17 2013, 04:15 AM
chads74   spoke I am pretty sure my ignition switch was p...   Sep 17 2013, 06:19 AM
jimkelly   spoke image 6 - the blue wire loops around and co...   Sep 16 2013, 07:31 PM
Spoke   spoke image 6 - the blue wire loops around and c...   Sep 17 2013, 06:49 AM
dwillouby   I dont use the relay board. You need a switched 12...   Sep 17 2013, 06:42 AM
jimkelly   I was thinking that since it seems to be the only ...   Sep 17 2013, 07:03 AM
jimkelly   finally going to put my crimper and heat shrink to...   Sep 17 2013, 08:01 AM
jimkelly   starter, shift linkage, gear oil, coolant fill nec...   Sep 20 2013, 12:45 PM
76-914   Jim, are you doing this and the Suby conversion or...   Sep 20 2013, 02:19 PM
jimkelly   I simply want to get the 1972 V8 running and funct...   Sep 20 2013, 03:24 PM
jimkelly   just goofing around, since I already have a bar th...   Sep 21 2013, 08:34 AM
zambezi   yes they grind better and produce less heat. Easi...   Sep 21 2013, 12:31 PM
jimkelly   engine bay shift rod done : ) 40.75" it is ...   Sep 21 2013, 01:15 PM
jimkelly   some random pics   Sep 22 2013, 11:22 AM
kg6dxn   Your lower spring perch is upside down... :( http...   Sep 22 2013, 07:17 PM
jimkelly   thanks for that!!! jim   Sep 22 2013, 07:45 PM
jimkelly   don't be an idiot like me. anyway, one flippe...   Sep 23 2013, 07:41 AM
76-914   Is that a "red" ground wire? <_<   Sep 23 2013, 03:04 PM
jimkelly   from the relay board to the body? yes. I will ch...   Sep 25 2013, 09:27 AM
jimkelly   also - before, I had the pos from alt running to p...   Sep 25 2013, 09:35 AM
kg6dxn   also - before, I had the pos from alt running to ...   Sep 25 2013, 09:01 PM
jimkelly   mike - I will get those wires buttoned up - thanks...   Sep 26 2013, 09:34 AM
jimkelly   guess i'll run the coolant lines today. the 2...   Sep 29 2013, 08:25 AM
jimkelly   well, not sure I like the relatively short 90 degr...   Sep 29 2013, 03:14 PM
bulitt   I may have to get one of those 90's.   Sep 29 2013, 06:33 PM
jimkelly   since the only electrical connector I have, that h...   Sep 30 2013, 07:32 AM
jimkelly   rcvd the 90 degree tube today - looks good.   Oct 2 2013, 09:18 AM
andys   Much nicer with that aluminum 90! Andys   Oct 2 2013, 09:26 AM
speed metal army   Hey Jim, weather pack electrical connectors are a ...   Oct 2 2013, 10:05 PM
jimkelly   well, my car had a big gap, at top, between the dr...   Oct 7 2013, 11:41 AM
JRust   Yeah the aluminum 90% was a good move. I didn...   Oct 7 2013, 08:11 PM
jimkelly   well two issues. I need to either come up with a ...   Oct 9 2013, 01:12 PM
JRust   The big washer with the groove goes on the bottom ...   Oct 9 2013, 03:17 PM
jimkelly   I have been searching and have yet to find a pic o...   Oct 9 2013, 04:57 PM
JRust   I have been searching and have yet to find a pic ...   Oct 10 2013, 07:20 AM
jimkelly   instead of this jumble of parts, I am thinking of ...   Oct 10 2013, 06:29 AM
bulitt   I'm thinking you will break your trans ears of...   Oct 10 2013, 06:50 AM
jimkelly   for engine mounts, found washers that fit perfectl...   Oct 10 2013, 07:34 AM
Chris H.   Hijack but this exhaust setup is AWESOME That...   Oct 10 2013, 09:43 AM
jimkelly   good point. behind trans is where the most space ...   Oct 10 2013, 09:51 AM
mittelmotor   I like the 2-in/2-out approach as well. Keeps the ...   Oct 10 2013, 01:22 PM
jimkelly   well, finally got a battery today. hooked it up, ...   Oct 10 2013, 01:41 PM
jimkelly   hooked my fuel to gas but she backfires and pops. ...   Oct 11 2013, 07:24 AM
wndsrfr   hooked my fuel to gas but she backfires and pops....   Oct 11 2013, 07:53 AM
DBCooper   or is this round mark at top of flywheel the tdc ...   Oct 11 2013, 09:51 AM
jimkelly   firing order seems to be 18436572 but finding tdc ...   Oct 11 2013, 08:22 AM
jimkelly   thanks guys, you've given me good guidance. dt...   Oct 11 2013, 10:36 AM
tooms351   Run a wire with allegator clips from starter selen...   Oct 11 2013, 04:40 PM
jimkelly   I basically have the with my console - but will tr...   Oct 11 2013, 05:52 PM
DBCooper   It looks like the number 1 wire goes up to the lef...   Oct 11 2013, 04:42 PM
jimkelly   all the images i found have cylinders 1-2 3-4 5-6...   Oct 11 2013, 05:24 PM
jimkelly   db I could kiss you, right on the mouth. GREAT eye...   Oct 11 2013, 06:09 PM
Chris H.   db I could kiss you, right on the mouth. Note ...   Oct 12 2013, 12:02 PM
jimkelly   attached my throttle bracket and throttle cable, a...   Oct 14 2013, 08:55 AM
jimkelly   set back. fuse box was in contact with block and ...   Oct 16 2013, 02:10 PM
Chris H.   Whew you dodged a bullet on that one Jim. Check J...   Oct 16 2013, 06:35 PM
jimkelly   I neglected the first rule - disconnect battery wh...   Oct 16 2013, 06:49 PM
bulitt   I neglected the first rule - disconnect battery w...   Oct 18 2013, 04:22 PM
jimkelly   I thought I may have fried my coil or dist but tha...   Oct 18 2013, 04:02 PM
jimkelly   price is right. once this Bacardi wears off, I ca...   Oct 18 2013, 04:28 PM
jimkelly   yesterday... filled cooling system with water, spl...   Oct 21 2013, 01:32 PM
jimkelly   plumbed to carb from firewall, pump and filter. n...   Oct 24 2013, 11:06 AM
jimkelly   next to install fuel tank and plug the return line...   Oct 24 2013, 03:13 PM
jimkelly   got my fuel tank in and fuel pump wired. I need to...   Oct 25 2013, 01:31 PM
rhodyguy   did you use the jumper wire from the engine relay ...   Oct 26 2013, 07:48 AM
jimkelly   yes - like this. http://www.914world.com/bbs2/upl...   Oct 26 2013, 07:52 AM
kg6dxn   yes - like this. As I ponder your symptoms... D...   Oct 27 2013, 08:26 PM
rhodyguy   the only way to go and still utilize the stock cir...   Oct 26 2013, 07:55 AM
jimkelly   I could have sworn my car started from key with th...   Oct 27 2013, 07:16 AM
Spoke   I still have 2 gremlins, drivers side parking lig...   Oct 27 2013, 08:01 AM
jimkelly   I will check. I assume you mean both filaments in...   Oct 27 2013, 08:36 AM
jimkelly   now I am seeing problems everywhere. I pulled a t...   Oct 27 2013, 08:29 AM
jimkelly   spoke - just tested your directionals rewiring - w...   Oct 27 2013, 09:11 AM
jimkelly   well - later tach won't do. it only has one g...   Oct 27 2013, 11:21 AM
Spoke   Yeah, I didn't like the later tach because of ...   Oct 27 2013, 02:53 PM
jimkelly   pretty sure its plastic - but I will put it back i...   Oct 27 2013, 03:44 PM
jimkelly   been off on a tangent with - spoke, dave darling, ...   Nov 2 2013, 08:53 AM
jimkelly   ok - she started off the ign key and ran for some ...   Nov 2 2013, 09:08 AM
kg6dxn   You should mount the fuel pump in the front of the...   Nov 2 2013, 09:36 AM
rhodyguy   rotary pump? if you don't want to do the front...   Nov 2 2013, 11:46 AM
jimkelly   I checked for a clog or other issue, gas all over ...   Nov 2 2013, 02:46 PM
bulitt   Obvious Question Jim- do you have gas in the tank?   Nov 2 2013, 07:47 PM
jimkelly   yes - about 3 gallons - and it spills out if I dis...   Nov 3 2013, 06:29 AM
jimkelly   dropped ground, but still no good. put car back o...   Nov 4 2013, 01:23 PM
mittelmotor   Nice progress. I've heard the pumps are much b...   Nov 4 2013, 05:17 PM
jimkelly   thanks. lots of pics for those few, that may be l...   Nov 4 2013, 07:28 PM
Mike Bellis   The Permatex sealant is the best one I've ever...   Nov 4 2013, 08:00 PM
DBCooper   I've used that stuff since I was a kid. Never...   Nov 5 2013, 08:53 AM
jimkelly   thanks guys for the comments on the permatex produ...   Nov 5 2013, 01:15 PM
jimkelly   pump in but will probably relocate fuel filter fur...   Nov 7 2013, 11:26 AM
rhodyguy   filter pior to the pump?   Nov 7 2013, 11:28 AM
jimkelly   its after pump. when I had pump higher, I had it ...   Nov 7 2013, 11:36 AM
jimkelly   i had temporarily removed my rear sway bar so I ca...   Nov 8 2013, 12:18 PM
Mike Bellis   From the pics, that looks like a very bad pump loc...   Nov 8 2013, 08:29 PM
jimkelly   I too have smashed my share of hose straps but did...   Nov 8 2013, 08:40 PM
- Lo-Fi Version Time is now: 12th August 2026 - 04:37 AM
