thelogo. charging your dead optima, cheap fix procedure |
rhodyguy |
Jun 7 2013, 07:43 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,085 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
not wanting to buy a new battery to replace my almost fully discharged (.4 v) one i found this online. take a KNOWN fully charged bat and connect the dead one in parallel with a set of jumper cables, +to+ and -to-. connect the charger to the dead bat and charge for 1 hour. then remove the jumpers and charge the previously dead one as normal. it worked GREAT!! not wanting to overcharge by letting the trickle charger run all night i stopped last evening and i checked the v this am. lost .1 volts. on a recharge mode this am for a full charge. if successful its money in the bank.
Porsche930dude |
Nov 8 2013, 05:00 PM
Member Group: Members Posts: 399 Joined: 25-November 11 From: Vestal NY Member No.: 13,819 Region Association: None |
I started doing a bit of expearimenting. With the help of U-tube (IMG:style_emoticons/default/smile.gif) I discovered a good trick of using ebsom salt to desulfate batteries. That paired with a capactive battery charger should repair most batteries. I didnt have any ebsom salt around but I thew together a capaitive charger with spare parts its super simple. and it seems to work great. I got a stone dead battey to full charge. I have yet to see if it will hold the charge but usually they take a few cycles to get them going again. Anyhow I thought id share my findings and I encourage you guys to look into it if you are intrested in fixing your batterys
thelogo |
Nov 10 2013, 07:24 AM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
I started doing a bit of expearimenting. With the help of U-tube (IMG:style_emoticons/default/smile.gif) I discovered a good trick of using ebsom salt to desulfate batteries. That paired with a capactive battery charger should repair most batteries. I didnt have any ebsom salt around but I thew together a capaitive charger with spare parts its super simple. and it seems to work great. I got a stone dead battey to full charge. I have yet to see if it will hold the charge but usually they take a few cycles to get them going again. Anyhow I thought id share my findings and I encourage you guys to look into it if you are intrested in fixing your batterys I have a multimeter , I have recharged my battery with.maintainer About to reinstall in car , can anyone. Tell me how.to test my alternator. So I can determine weather.or not.to.replace.just battery or both battery and alternator. |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:05 PM |
