thelogo. charging your dead optima, cheap fix procedure |
rhodyguy |
Jun 7 2013, 07:43 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,085 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
not wanting to buy a new battery to replace my almost fully discharged (.4 v) one i found this online. take a KNOWN fully charged bat and connect the dead one in parallel with a set of jumper cables, +to+ and -to-. connect the charger to the dead bat and charge for 1 hour. then remove the jumpers and charge the previously dead one as normal. it worked GREAT!! not wanting to overcharge by letting the trickle charger run all night i stopped last evening and i checked the v this am. lost .1 volts. on a recharge mode this am for a full charge. if successful its money in the bank.
pcar916 |
Nov 10 2013, 07:53 AM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
Checking alternator output...
Check the voltage after you start the car and with a bit of throttle applied. Your voltage at the battery should be slightly over 13v. If it's less than ~12.8v your alternator/voltage regulator (separate in early cars) is suspect. I don't know the year the v-regulator was integrated into the alternator... others here will know. Good luck |
thelogo |
Nov 10 2013, 03:47 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
Checking alternator output... Check the voltage after you start the car and with a bit of throttle applied. Your voltage at the battery should be slightly over 13v. If it's less than ~12.8v your alternator/voltage regulator (separate in early cars) is suspect. I don't know the year the v-regulator was integrated into the alternator... others here will know. Good luck I suspect optima is finished because it s voltage falls steadily when I take off The maintainer , even know the battery is removed from the car But I guess five good years is a alright shelf life |
thelogo |
Nov 10 2013, 03:50 PM
Checking alternator output... Check the voltage after you start the car and with a bit of throttle applied. Your voltage at the battery should be slightly over 13v. If it's less than ~12.8v your alternator/voltage regulator (separate in early cars) is suspect. I don't know the year the v-regulator was integrated into the alternator... others here will know. Good luck I suspect optima is finished because it s voltage falls steadily when I take off The maintainer , even know the battery is removed from the car But I guess five good years is a alright shelf life "" Pathetic ,paranoid and lost in the past , let me tell you something , I am a legend and legends are not f*cking, pathetic. The great Ty Cobb |
Lo-Fi Version | Time is now: 2nd June 2024 - 03:12 PM |
