2.0L MPS and today's gas, Recalibrated? |
boxsterfan |
Nov 12 2013, 11:27 AM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
On my 74 2.0L, I have MPS (Part#: 280 100 043). I am not having an existing problem with my MPS, but with today's gasoline (ethanol blends, etc..) should an MPS be recalibrated for optimum operation? I typically fill up with Chevron 91 premium.
Of course, if it's not broke then don't fix it... |
gunny |
Nov 12 2013, 12:26 PM
Member Group: Members Posts: 205 Joined: 17-October 12 From: Madison Al Member No.: 15,051 Region Association: South East States |
I use 87 octane as that is what the car was designed to run on. Save the money and add a wideband A/F mixture gage. You will then know if you need to adjust your MPS. I have a 76 with a calibrated MPS but was still running lean until I made the adjustments to richen it up.
Just my $.02 |
ressex |
Nov 12 2013, 12:42 PM
Newbie Group: Members Posts: 8 Joined: 26-December 12 From: London - but the US part of the year Member No.: 15,284 Region Association: None |
I use 87 octain as that is what the car was designed to run on. Save the money and add a wideband A/F mixture gage. You will then know if you need to adjust your MPS. I have a 76 with a calibrated MPS but was still running lean until I made the adjustments to richen it up. Just my $.02 Hi - I'm glad this issue has come-up because I just bought a '76 2.0 with injection and pollution controls intact - found on 914world! I wasn't sure what to run and the previous owner had said 89 at most. I had assumed I should run higher and the little sticker in front says 91 but the octane rating were different then? Thanks. |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:01 AM |
