Fuel pump |
Fuel pump |
vagabundo |
Nov 13 2013, 03:56 PM
Newbie Group: Members Posts: 10 Joined: 1-October 04 From: Murphys, CA Member No.: 2,870 |
I posted this on the PP BBS but thought I would start this here to see if a wider audience might help.
I am the original owner of a 1973 2.0 with stock EFI and about 115K miles. Several years ago I had a shop relocate the fuel pump up front while I had the tank out. The car hasn't been driven much since then but I got back on the road recently and the car was driving great after I sorted out some relay problems. Last week I had to jump start the car knowing the battery was shot. Car was runnin', so I took it out but could not restart to get it back home, even with a jump. My local mechanic replaced the battery and was able to get the car started but it appears the fuel pump is shot (he tapped it with a l'il hammer to get it going). Here's my problem -- I know these 2.0 pumps are NLA but I could take out the pump and send it Auto ATL for a rebuild. I saw on another thread that the ground wire could be a culprit, so I'm going to check that first. Are there any other things I should be looking at before I take out the pump? I would hate to miss a shade-tree fix before I go down that road. Thanks in advance for any helpful advice. vb |
JawjaPorsche |
Nov 13 2013, 05:00 PM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
NAPA has new Bosch Fuel Pump. I assume yours is a two prong pump? The three prong pump is NLA but the two prong is still available. If you have a three prong, you can use the two prong pump with no problem.
Part number BSH 69133 |
Lo-Fi Version | Time is now: 12th June 2024 - 04:42 AM |
