| Bulldog9 |
Aug 21 2013, 08:44 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 706 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
I'm restoring a 912E, total gut & rebuild. New to this forum, been on the 912 board and several others for a while. I've never worked on an air cooled car engine before, or VW/Porsche of any type, so this has been a real learning process. Been lurking here for a while, figured it was time to post. I've been on 912BBS since 2011, for those interested, this link goes back to day 1. http://www.912bbs.org/vb/showthread.php?43391-770-Update
| Bulldog9 |
Nov 14 2013, 07:17 AM
Thanks all, I decided on the CB rotary pump.
I just finished media blasting the fan, will be painting then sending crank, fan flywheel, and PP to be balanced. I weighed my piston/ring/rod assemblies and tehy are almost spot on, but will match opposing sides as close as possible. Quick question, I have been planning on using permatez aviation sealant for my case/assembly sealent, is this still the conventional wisdom? \ |
| Jeffs9146 |
Nov 14 2013, 11:12 AM
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Thanks all, I decided on the CB rotary pump, and will likely use the Fram filter with the built in bypass as a second filter. The Jeep guys use this when running Weber IDF's with great results. I just finished media blasting the fan, will be painting then sending crank, fan flywheel, and PP to be balanced. I weighed my piston/ring/rod assemblies and tehy are almost spot on, but will match opposing sides as close as possible. Quick question, I have been planning on using permatez aviation sealant for my case/assembly sealent, is this still the conventional wisdom? I'm going to try to keep all my questions and posts on the car in this thread, would like to rename it if possible, to #770 Build Project (my 912E is #770 of about 2000). Moderators??? You can change the title yourself by going to your first post while loged in and click on edit, then full edit and go to the top of the new screen and change your title! |
| Bulldog9 |
Nov 14 2013, 12:33 PM
thanks!
Steve Pratel #770 (912E) Project thread *Tangerine Cooling System installed!) Aug 21 2013, 08:44 PM
kg6dxn :wttc: Aug 21 2013, 08:48 PM
76-914 :wttc: Aug 21 2013, 09:09 PM
PanelBilly WElcome. Aug 21 2013, 09:10 PM
JawjaPorsche We need pictures!
:wttc: Aug 22 2013, 02:09 AM
aharder :wttc: Aug 22 2013, 06:40 AM
Drums66 ....WELCOME...man! Aug 22 2013, 10:29 AM
Joe Sharp :wttc:
:ttiwwp: Aug 22 2013, 10:42 AM
gunny :wttc: Aug 22 2013, 11:12 AM
krazykonrad :wttc: Aug 22 2013, 06:12 PM
green914 :wttc: Aug 22 2013, 06:31 PM
Steve Pratel OK, here is a quick journey, focus mainly on the m... Aug 22 2013, 06:36 PM
Steve Pratel more of car overall Aug 22 2013, 06:40 PM
Steve Pratel As is evident the car is basically solid, just fil... Aug 22 2013, 06:46 PM
Steve Pratel Here is how the floor and interior look today. I s... Aug 22 2013, 06:50 PM
Steve Pratel Engine Pics I never took a pic of whta the engine ... Aug 22 2013, 07:01 PM
Steve Pratel drop & dissasemble Aug 22 2013, 07:04 PM
Steve Pratel Overall the internals of the engine were in good s... Aug 22 2013, 07:42 PM
Steve Pratel very little scuffing shows the car was lightly use... Aug 22 2013, 07:46 PM
Steve Pratel cases split very easily, though I was surprised at... Aug 22 2013, 07:53 PM
Socalandy :wttc: Aug 22 2013, 07:54 PM
dale73914 Why someone would leaave this to rot is beyond me.... Aug 22 2013, 10:39 PM
SirAndy Why someone would leaave this to rot is beyond me.... Aug 23 2013, 10:46 AM
Steve Pratel
Why someone would leaave this to rot is beyond me... Aug 23 2013, 12:17 PM
anderssj
Why someone would leave this to rot is beyond me... Nov 20 2013, 06:31 PM
Steve Pratel
Hi Steve,
Very nice project! Wow, lots of ... Nov 21 2013, 09:48 AM
stugray I never realized that the 912s had 4 cyls in them.... Aug 23 2013, 12:37 PM
Jgilliam914
I never realized that the 912s had 4 cyls in them... Aug 23 2013, 01:08 PM
poorsche914 The '76 912E had the same 2.0 as our 914s but ... Aug 23 2013, 01:15 PM
Steve Pratel
I never realized that the 912s had 4 cyls in them... Aug 26 2013, 10:44 AM
Jgilliam914 To Steve :wttc: you will have a blast working on ... Aug 23 2013, 01:12 PM
stugray
So do the 912E owners get "looked down upon... Aug 23 2013, 05:31 PM
injunmort not to be a douche but butdo you guys care about m... Aug 23 2013, 08:03 PM
Mikey914
not to be a douche but butdo you guys care about ... Aug 23 2013, 10:00 PM
speed metal army
not to be a douche but butdo you guys care about ... Aug 23 2013, 11:30 PM
Jonathan Livesay
not to be a douche but butdo you guys care about ... Aug 29 2013, 05:09 PM
Joe Sharp
not to be a douche but butdo you guys care about ... Nov 14 2013, 11:35 AM
Mikey914 This is what it will look like when it's done-... Aug 23 2013, 09:55 PM
euro911 Cool. It would be a 2056 with those P/Cs :)
Wha... Aug 23 2013, 11:42 PM
euro911 2.0L T4 with L-jet FI Aug 26 2013, 11:27 AM
Dr Evil Not sure if a lot of people already mentioned this... Aug 26 2013, 07:59 PM
euro911 :stooges: Aug 26 2013, 11:50 PM
Nine_14 Looks like the previous owner was not an Porsche e... Aug 27 2013, 10:30 AM
Steve Pratel Thanks for the welcome guys, I will definitely be ... Aug 29 2013, 04:55 PM
euro911 Thanks for the welcome guys, I will definitely be ... Aug 29 2013, 07:13 PM
Steve Pratel
Thanks for the welcome guys, I will definitely be... Sep 3 2013, 08:58 PM
euro911 Another neat trick is to drill a 1/2" hole in... Sep 5 2013, 04:41 PM
Cap'n Krusty
Another neat trick is to drill a 1/2" hole i... Nov 30 2013, 08:32 PM
Steve Pratel Am looking at a couple fuel pumps for my build.
I... Nov 11 2013, 07:05 PM
http://www.cbperformance.com/ProductDetail...rodu... Nov 11 2013, 08:08 PM
euro911 Am looking at a couple fuel pumps for my build.
I... Nov 11 2013, 10:20 PM
Kirmizi Rotary pumps, like the one from CB Performance, ar... Nov 11 2013, 09:39 PM
StratPlayer Clean off the fan with some brake cleaner, if you... Nov 12 2013, 10:30 AM
euro911
Thanks all, I decided on the CB rotary pump, and ... Nov 14 2013, 01:15 PM
Joe Sharp So I'm cooking today to get ready for dinner t... Nov 14 2013, 12:42 PM
Steve Pratel And the fan is finished being blasted and painted.... Nov 19 2013, 07:20 PM
euro911 Nice. I can already tell how the rest of the motor... Nov 19 2013, 08:14 PM
PanelBilly Since you changed your title, I guess my "WEc... Nov 19 2013, 08:42 PM
Steve Pratel
Since you changed your title, I guess my "WE... Nov 20 2013, 08:03 AM
FourBlades Great project!
Seems like you have a good pl... Nov 20 2013, 09:19 AM
Al Meredith Steve, I have had 3 912Es , now own #265. I built ... Nov 20 2013, 08:21 PM
Steve Pratel This is what I am hoping for, not looking to brack... Nov 21 2013, 09:56 AM
gothspeed I would love a 912E .... except they still have to... Nov 20 2013, 09:28 PM
Steve Pratel I never even heard of one untill I found this car,... Nov 21 2013, 10:02 AM
gothspeed
I never even heard of one untill I found this car... Nov 21 2013, 12:54 PM
type47
... and the reality that I will have a motor with... Jan 26 2014, 05:10 PM
Steve Pratel
... and the reality that I will have a motor wit... Jan 26 2014, 05:30 PM
euro911 Get a '74 or a '75 911 and drop a T4 in it... Nov 20 2013, 11:15 PM
oldschool
Get a '74 or a '75 911 and drop a T4 in i... Dec 1 2013, 09:59 PM
gothspeed
Get a '74 or a '75 911 and drop a T4 in i... Dec 5 2013, 12:00 AM
Steve Pratel SWEET! Just picked these up off ebay. NOS ne... Nov 21 2013, 09:47 AM
Dave_Darling There were, I believe, 2100 of the 912E made. Som... Nov 21 2013, 10:07 AM
euro911 There was legislation introduced to increase it to... Nov 21 2013, 01:00 PM
gothspeed
There was legislation introduced to increase it t... Nov 21 2013, 04:39 PM
Mikey914
There was legislation introduced to increase it t... Nov 30 2013, 07:45 PM
euro911 Yeah, they need to keep up with the times and move... Nov 21 2013, 05:34 PM
Steve Pratel Some progress, I jacked the car up and put on stan... Nov 30 2013, 07:21 PM
Steve Pratel and the rear Nov 30 2013, 07:23 PM
Steve Pratel ..The pile of stuff. Will be dumping the rotors, a... Nov 30 2013, 07:25 PM
Steve Pratel passenger front end parts I removed today. Nov 30 2013, 07:45 PM
euro911 Looks like you've been a busy boy.
If the car... Nov 30 2013, 07:56 PM
euro911 Topside, TDC for timing with an adjustable timing ... Nov 30 2013, 09:02 PM
Steve Pratel Gents, diddnt want to start a new thread, and tryi... Dec 4 2013, 08:41 PM
Jake Raby For adequate performance for 5,500 RPM or below th... Dec 4 2013, 08:59 PM
Steve Pratel OK, things have been hectic the last week, back to... Dec 11 2013, 07:31 AM
Steve Pratel I've been busy on #770, here is a link to the ... Jan 26 2014, 04:30 PM
type47 well, I know Jake does magic with typeIV motors bu... Jan 26 2014, 06:24 PM
Steve Pratel
well, I know Jake does magic with typeIV motors b... Jan 26 2014, 07:14 PM
Steve Pratel R&R'd the steering rack and front cross me... Feb 1 2014, 05:41 PM
barefoot
R&R'd the steering rack and front cross m... Feb 10 2014, 07:53 AM
Steve Pratel Snow day today, so I figured I'd try my electr... Feb 13 2014, 08:42 PM
Jake Raby Consider the sprung weight difference of the two e... Feb 1 2014, 07:23 PM
Steve Pratel A few more projects completed. Paint is PJ1/VHT en... Feb 3 2014, 09:29 PM
Steve Pratel Decided to go silver with the shift lever. Took le... Feb 3 2014, 09:34 PM
euro911 Excellent :) Feb 3 2014, 09:37 PM
Steve Pratel Getting psyched, just ordered the rebel racing bus... Feb 5 2014, 04:16 PM
Steve Pratel OK, I'm not above begging...............
Anyo... Feb 9 2014, 10:56 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th October 2026 - 01:21 AM |
