Oil light green, Drove it, sat running suddenly oil under car oil light comes on |
LINGO |
Nov 16 2013, 07:18 PM
Newbie Group: Members Posts: 29 Joined: 26-October 13 From: Jackson, Michigan Member No.: 16,571 Region Association: Upper MidWest |
Ok I know this isn't good. I drove the car for 30 mins, ran it thru a car wash and then home where I let it sit idling for about 20 mins while I was drying it off. I get back in car and noticed Green oil light came on so I shut it down. Looked under car and a lot of oil on ground. I check oil level after it cools down and it's perfect? So I start car move it to garage. Hour later oil level still ok so I try to start and it sounds like it is about to turn over But it doesn't? I know the green light is bad so I'm waiting for some of your valued input what I do from here?
LINGO |
Nov 16 2013, 08:47 PM
Well I checked it again tonite. Oil level good but a very dim green light was there. I started it up and it ran but I shut it off after 15 seconds fearing I may damage something. When I turned key off and back on again it was bright green? At least it's starting up again? I checked the sensor area it had some oil in the area. I took off the wire and cleaned it up as well as any oil. Am I looking at a bad oil sensor?
Lo-Fi Version | Time is now: 11th June 2024 - 07:19 AM |
