> 215mm or 228mm clutch/pressure plate??, stock okay or need HD for conversion??
Mueller
post Jul 27 2004, 05:34 PM
914 Freak!
new motor will be putting out a little over 175hp/torque, I have a brand new 6-spring clutch and brand new pressure plate already for my stock /4 motor....will these be okay for my new motor??
according to KEP, the stock setup is good for 180ft. lbs, with the 914 being light and not having too much rear tire, should I be okay or should I spend the extra $100 for the larger heavier duty rated clutch package??
as copied from Kennedy Engineered Products
Stock - (for comparison). Holds 180 ft. lbs. of torque.
Stage I - 215mm Pressure Plate. Holds 230 ft. lbs. of torque.
Stage II - 215mm pressure Plate. Holds 270 ft. lbs. of torque.
9" STOCK        200 ft. lb.
9" STAGE I      223 ft. lb.
9" STAGE II     273 ft. lb.
9" STAGE III    378 ft. lb
Are heavier duty clutch and pressure plates available so that if for some reason KEP no longer carries them I can get a replacment from the normal P-car places?
bondo
post Jul 27 2004, 07:14 PM
I know renegade also sells a 9" clutch package, so there's at least one more source. As far as what clutch to choose, I'm also trying to choose a clutch from them. I haven't been able to get a straight answer from KEP about what each setup's dynamic torque ratings are. I'm looking for a clutch for my v8 that puts out 325 ft-lbs. I don't want it to start slipping once it's engaged, but if I dump the clutch (shock load), I don't want it to transmit more than 300 ft-lbs into the trans. Ideally I would want a clutch with a static rating of over 325, and a dynamic rating that's under 300.. I don't know if such an animal exists though.
Mueller   215mm or 228mm clutch/pressure plate??   Jul 27 2004, 05:34 PM
bondo   I know renegade also sells a 9" clutch package, so...   Jul 27 2004, 07:14 PM
skline   Renegade sells Kennedy clutches so that is the sam...   Jul 27 2004, 07:43 PM
Brad Roberts   Mike, I run the KEP 228 stageII in everything tha...   Jul 27 2004, 07:48 PM
Mueller
  Jul 27 2004, 07:53 PM
Brad Roberts   KEP actually likes me. When I call them with an is...   Jul 27 2004, 07:57 PM
Howard R   I'm in the process of changing from the standa...   Jul 27 2004, 08:03 PM
Mueller
  Jul 27 2004, 08:09 PM
Brad Roberts   Why would you have a pull type setup ?? B   Jul 27 2004, 08:11 PM
Mueller   push, pull, I don't know, whatever the stock s...   Jul 27 2004, 08:17 PM
TimT   Kinda hijacking Mikes thread, Howard, here is th...   Jul 27 2004, 08:20 PM
Howard R   Because I have already got the 915 flywheel and al...   Jul 27 2004, 08:21 PM
Howard R   Thanks Tim. Did you have to move the pivot and wh...   Jul 27 2004, 08:26 PM
TimT   Used a 2.2 ball, the pivot has to be moved a bit.....   Jul 27 2004, 08:33 PM
bondo
- Lo-Fi Version Time is now: 2nd April 2026 - 11:34 AM
