| Mueller |
Jul 27 2004, 05:34 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
new motor will be putting out a little over 175hp/torque, I have a brand new 6-spring clutch and brand new pressure plate already for my stock /4 motor....will these be okay for my new motor??
according to KEP, the stock setup is good for 180ft. lbs, with the 914 being light and not having too much rear tire, should I be okay or should I spend the extra $100 for the larger heavier duty rated clutch package?? as copied from Kennedy Engineered Products QUOTE Stock - (for comparison). Holds 180 ft. lbs. of torque. Stage I - 215mm Pressure Plate. Holds 230 ft. lbs. of torque. Stage II - 215mm pressure Plate. Holds 270 ft. lbs. of torque. QUOTE 9" STOCK 200 ft. lb. 9" STAGE I 223 ft. lb. 9" STAGE II 273 ft. lb. 9" STAGE III 378 ft. lb Are heavier duty clutch and pressure plates available so that if for some reason KEP no longer carries them I can get a replacment from the normal P-car places? |
| TimT |
Jul 27 2004, 08:33 PM
retired ![]() ![]() ![]() ![]() Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
Used a 2.2 ball, the pivot has to be moved a bit.. the geometry is a bit different between the 2.2 fork , and the 2.0 fork. Ill have to look at my spare tranny, I think I set that one up for the pull clutch also...
Mike, back to your regularly scheduled programming (IMG:style_emoticons/default/beerchug.gif) |
Mueller 215mm or 228mm clutch/pressure plate?? Jul 27 2004, 05:34 PM
bondo I know renegade also sells a 9" clutch package, so... Jul 27 2004, 07:14 PM
skline Renegade sells Kennedy clutches so that is the sam... Jul 27 2004, 07:43 PM
Brad Roberts Mike,
I run the KEP 228 stageII in everything tha... Jul 27 2004, 07:48 PM
Mueller
Brad Roberts KEP actually likes me. When I call them with an is... Jul 27 2004, 07:57 PM
Howard R I'm in the process of changing from the standa... Jul 27 2004, 08:03 PM
Mueller
Brad Roberts Why would you have a pull type setup ??
B Jul 27 2004, 08:11 PM
Mueller push, pull, I don't know, whatever the stock s... Jul 27 2004, 08:17 PM
TimT Kinda hijacking Mikes thread,
Howard, here is th... Jul 27 2004, 08:20 PM
Howard R Because I have already got the 915 flywheel and al... Jul 27 2004, 08:21 PM
Howard R Thanks Tim. Did you have to move the pivot and wh... Jul 27 2004, 08:26 PM
bondo ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:11 AM |
