> 75 914 with D-Jettronic, need help diagnosing stuttering
Rant6
post Nov 19 2013, 01:45 PM
Hi folks. I have a nearly all original 1975 914 with the 2.0 engine. The car has 93k miles on it, and I have owned it for almost two years. I have been troubleshooting one particular problem for quite some time. The car runs perfectly with one exception. The engine hesitates or stutters often. It is a hard stutter, that is, it actually feels like maybe the ignition is cutting out for a fraction of a second, and so it causes a bucking sensation when driving the car. There are few discernible circumstances where this always occurs or never occurs. It seems to be random, and it can occur under easy acceleration, steady throttle, or off throttle (usually VERY slightly off throttle). It can occur under cold or hot conditions. It happens every time I drive the car, sometimes infrequently, but more often it happens constantly. It seems to happen most often in the middle of the RPM range, that is from about 2500 to 3200 RPM.
Some of the emission control stuff has been disconnected or removed from the car including the charcoal canister, the distributor vacuum retard, (I don't think there was a vacuum advance because I can't find where the hose would have connected to), the vacuum line to the decel valve, and an electrical 2-prong plug that goes into the intake plenum. I have done the following things:
Fuel injector cleaner
New plug wires
New plugs
New rotor/cap/points
New air cleaner
Re-attached the electrical plug in the intake plenum (this caused the idle to surge up and down 1200 RPM, so I disconnected it - what is this thing?)
Re-attached the vacuum line to the decel valve
Replaced the circuit board in the throttle position sensor, and aligned.
I really thought the last item was going to be the fix, but it had no effect at all.
Can anyone offer some possible causes?
Thanks,
Mike
post Nov 19 2013, 02:50 PM
Did you carefully examine the fingers on the TPS when you replaced the board? If they are twisted a tad they ride off track or on their sides. Or, just disconnect the plug at the TPS to see if it goes away. Also, what is your fuel pressure? I've read that bumping it up a pound will sometimes eliminate this bucking but I can't confirm it.
WPEngels
post Nov 21 2013, 06:10 AM
Hi,
I had the same symptoms on my '74 car after swapping the engine. It ran absolutely fine before, but stuttered after putting the engine back in.
I considered replacing several parts but luckily before spending a lot on new parts, I found a loose connector on the common ground point on the engine (on top of the engine, just in front of the transmission). Also, one of the cables was almost compleely severed. Must have been me trying to get the engine tin back into place, catching the cable between the tin and the engine casing.
Anyway, repairing this cable and making the connector fit tightly again solved the problem.
Kind regards,
Wilbert
- Lo-Fi Version Time is now: 12th July 2025 - 10:44 AM
