mikesmith |
Member ![]() ![]() Group: Members Posts: 202 Joined: 5-September 13 From: SF Member No.: 16,354 Region Association: Northern California ![]() |
Sorting out the PO & Renegade's ... interesting wiring and I'm looking at the ground path.
Starting at the battery negative terminal, there's a cable runs to the back of the alternator pivot bolt (not to the chassis), then there's the transaxle ground cable away back at the back end of things. I'm fairly sure that this is part of why I am only seeing 10V at the dash with fans and headlights on (lots of ground path resistance). Where was the battery ground originally connected? Worst case I can just run another 2ga cable down to the transaxle ground, but that seems a bit silly. If I can, I'd like to find a well-grounded bolt nearer the battery... Thanks for any suggestions. I think a 105A alternator is also in my near future. |
ThePaintedMan |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States ![]() ![]() |
Mine is grounded with a negative cable that goes to the top trans/motor bolt. It seems to work, but at some point I need to replace the lug that goes through the body which serves as a ground, as Curt mentioned.
914itis |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States ![]() |
ThePaintedMan |
Mine is grounded with a negative cable that goes to the top trans/motor bolt. It seems to work, but at some point I need to replace the lug that goes through the body which serves as a ground, as Curt mentioned. And no electrical issues? You need both. Sorry, my fault Paul, should have been more clear. I don't have a picture, but the negative battery cable runs to the long engine-to-transmission bolt behind the #3 cylinder, exactly opposite of the one holding the top of the starter on. I still also have the transmission ground strap as well. No electrical issues....for the most part. The ones I do have are my own damn fault (need a fog light relay). Eventually I'll find something that will work to replace the broken-off original negative ground above the battery. But for now, this works. |
Lo-Fi Version | Time is now: 16th June 2024 - 02:31 PM |
