> MS guru's! What MS for a /6 turbo?, researching and deciding on a system, bit OT, it's for a 930
Mark Henry
post Nov 27 2013, 10:34 PM
that's what I do!
Researching a FI system for a buddies late model 930, not much more than a low mile stock 3.4 engine with cams and a bit beefier snail.
I have another bud with a totally gonzo 930 with SDS, that car is a rocket (450+hp, extreme heads, paulter rods...etc.) and the SDS runs flawless on it, so SDS is in the running......But this guy has a clewette/electomotive crankfire (missing tooth) dual plug coilpack system already, so MS is a definite candidate as well.
So what would be the best system that uses (ties into) the existing ignition?
I can solder or would a finished system (like MS3 pro) be better?
I know many of you have gone this route so I'm hoping to pick some brains. (IMG:style_emoticons/default/smile.gif)
jeff
post Nov 28 2013, 11:05 AM
This system is really nice, if money is no object I would go with a motec setup but this stuff works and is very user friendly...
http://sdsefi.com/
Mark Henry
post Nov 28 2013, 11:26 AM
that's what I do!
QUOTE(jeff @ Nov 28 2013, 12:05 PM) *
http://sdsefi.com/
SDS is in the running, if you read my first post you'll see I've installed several SDS systems including the system that was in my 914/4 that's now going on my bug.
In fact I was using SDS long before Jake was.
Mark Henry   MS guru's! What MS for a /6 turbo?   Nov 27 2013, 10:34 PM
McMark   I got MSIII.   Nov 27 2013, 10:48 PM
RonW   ms3 or microsquirt   Nov 27 2013, 11:04 PM
McMark   MicroSquirt won't handle ignition on a six if ...   Nov 27 2013, 11:25 PM
Mark Henry   MicroSquirt won't handle ignition on a six if...   Nov 27 2013, 11:39 PM
iamchappy   Im old school running a 86 Ruf CIS euro 930 fuel h...   Nov 27 2013, 11:25 PM
Mark Henry   Im old school running a 86 Ruf CIS euro 930 fuel ...   Nov 27 2013, 11:36 PM
Mark Henry   So what I'm reading is the build time on an EC...   Nov 28 2013, 06:44 AM
rick 918-S   So what I'm reading is the build time on an E...   Nov 28 2013, 08:25 AM
Mark Henry   Same deal for me. I've been to the MS web s...   Nov 28 2013, 08:40 AM
rick 918-S   Same deal for me. I've been to the MS web ...   Nov 28 2013, 08:47 AM
Mark Henry   [quote name='Mark Henry' post='1963545' date='Nov...   Nov 28 2013, 09:02 AM
rick 918-S   [quote name='Mark Henry' post='1963545' date='No...   Nov 28 2013, 09:18 AM
jimkelly   I believe you can get is assembled as well http:/...   Nov 28 2013, 10:05 AM
rick 918-S   I believe you can get is assembled as well http:...   Nov 28 2013, 10:54 AM
DBCooper   The SDS is "simple," which is good, but ...   Nov 28 2013, 11:37 AM
Mark Henry   Ya, I was surfing the microsquirt site and there...   Nov 28 2013, 11:45 AM
jeff   This system is really nice, if money is no object ...   Nov 28 2013, 11:05 AM
Mark Henry   This system is really nice, if money is no object...   Nov 28 2013, 11:26 AM
rfuerst911sc   If anyone is interested I have an Autronics unit I...   Nov 28 2013, 12:28 PM
McMark   The MegaSquirt main board has been through a few r...   Nov 28 2013, 01:13 PM
Mark Henry   The MegaSquirt main board has been through a few ...   Nov 28 2013, 01:31 PM
McMark   You got it. The CIS pump is higher pressure usual...   Nov 28 2013, 02:42 PM
rick 918-S   So like $ 500.00 and you still need to buy th...   Nov 28 2013, 03:32 PM
Mark Henry   So like $ 500.00 and you still need to buy t...   Nov 28 2013, 03:47 PM
rick 918-S   So like $ 500.00 and you still need to buy ...   Nov 28 2013, 03:53 PM
Mark Henry   [quote name='Mark Henry' post='1963709' date='Nov...   Nov 28 2013, 04:39 PM
McMark   :agree: this is why my complete setup is $300...   Nov 28 2013, 05:43 PM
Mark Henry   :agree: this is why my complete setup is $30...   Nov 28 2013, 05:54 PM
ConeDodger   :agree: this is why my complete setup is $30...   Nov 28 2013, 08:31 PM
Mark Henry   Mark, just a side thought on a totally different e...   Nov 28 2013, 08:26 PM
McMark   Mark, just a side thought on a totally different ...   Nov 29 2013, 01:14 PM
Mark Henry   [quote name='Mark Henry' post='1963802' date='Nov...   Nov 29 2013, 03:01 PM
r_towle   Mark, just a side thought on a totally different...   Nov 29 2013, 04:06 PM
edwin   I've been through this a few times now. My fir...   Nov 29 2013, 06:03 AM
Mark Henry   I've been through this a few times now. My fi...   Nov 29 2013, 07:42 AM
sixnotfour   I was going to run micro squirt, fuel only, but I ...   Nov 29 2013, 02:14 PM
McMark   Distributors have maintenance and timing settings,...   Nov 29 2013, 04:39 PM
mikesmith   No distributor means it's all up to the ECU a...   Nov 29 2013, 09:23 PM
McMark   No distributor means it's all up to the ECU ...   Nov 29 2013, 09:35 PM
DBCooper   yeah, but I can do COP way easier. So why would I ...   Nov 30 2013, 03:09 PM
Mark Henry   I got that dizzy dirt cheap for helping a bud with...   Nov 29 2013, 05:05 PM
Mark Henry   Well I'll wait on my /6 till the verdict is in...   Nov 30 2013, 07:31 AM
rick 918-S   I just came from Ross's house another local 91...   Nov 30 2013, 02:51 PM
McMark   Why would I add EDIS, when MicroSquirt can control...   Nov 30 2013, 07:03 PM
DBCooper   You don't need to use the EDIS module, that ge...   Nov 30 2013, 08:01 PM
mikesmith   Mark is (probably) talking about CNP using the GM ...   Nov 30 2013, 08:14 PM
DBCooper   Makes sense. I was curious because everyone aroun...   Nov 30 2013, 08:27 PM
McMark   Bosch makes a really easy ignitor as well for coil...   Nov 30 2013, 10:50 PM
ConeDodger   Bosch makes a really easy ignitor as well for coi...   Nov 30 2013, 10:56 PM
DBCooper   Really? What an odd comment, Rob. Those coils ha...   Dec 1 2013, 09:05 AM
ConeDodger   Really? What an odd comment, Rob. Those coils h...   Dec 1 2013, 02:23 PM
jd74914   Bulletproof?? Really? The first time I saw an EDI...   Dec 1 2013, 02:48 PM
McMark   I looked at EDIS over the weekend. I still don...   Dec 1 2013, 02:19 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:20 AM
