| Mark Henry |
Nov 27 2013, 10:34 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Researching a FI system for a buddies late model 930, not much more than a low mile stock 3.4 engine with cams and a bit beefier snail.
I have another bud with a totally gonzo 930 with SDS, that car is a rocket (450+hp, extreme heads, paulter rods...etc.) and the SDS runs flawless on it, so SDS is in the running......But this guy has a clewette/electomotive crankfire (missing tooth) dual plug coilpack system already, so MS is a definite candidate as well. So what would be the best system that uses (ties into) the existing ignition? I can solder or would a finished system (like MS3 pro) be better? I know many of you have gone this route so I'm hoping to pick some brains. (IMG:style_emoticons/default/smile.gif) |
| Mark Henry |
Nov 28 2013, 08:26 PM
Mark, just a side thought on a totally different engine (mine) on a 914.
Which MS would you grab for a N/A twin plug dizzy with MSD and webers. Been thinking that if I don't like the webers about doing a stealth nostalgia look using gutted carbs as TBs and hiding the FI as best I could. I'd still use the twin plug dizzy so it's a fuel only system. MS 2? or a 3 without the expansion card? (IMG:style_emoticons/default/confused24.gif) |
| McMark |
Nov 29 2013, 01:14 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Mark, just a side thought on a totally different engine (mine) on a 914. Which MS would you grab for a N/A twin plug dizzy with MSD and webers. Been thinking that if I don't like the webers about doing a stealth nostalgia look using gutted carbs as TBs and hiding the FI as best I could. I'd still use the twin plug dizzy so it's a fuel only system. MS 2? or a 3 without the expansion card? (IMG:style_emoticons/default/confused24.gif) If it's a four I would run microsquirt. I would also lean toward COP. Distributors are a pita. |
| Mark Henry |
Nov 29 2013, 03:01 PM
Mark, just a side thought on a totally different engine (mine) on a 914. Which MS would you grab for a N/A twin plug dizzy with MSD and webers. Been thinking that if I don't like the webers about doing a stealth nostalgia look using gutted carbs as TBs and hiding the FI as best I could. I'd still use the twin plug dizzy so it's a fuel only system. MS 2? or a 3 without the expansion card? (IMG:style_emoticons/default/confused24.gif) If it's a four I would run microsquirt. I would also lean toward COP. Distributors are a pita. This is for my engine It's a six with a jarvis/patrick twinplug MSD dizzy, kind of like to keep it....I'll see how it's on carbs first. (IMG:http://www.914world.com/bbs2/uploads_offsite/patrickms.s3.amazonaws.com-26-1385758882.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/patrickms.s3.amazonaws.com-26-1385758883.2.jpg) |
Mark Henry MS guru's! What MS for a /6 turbo? Nov 27 2013, 10:34 PM
McMark I got MSIII. Nov 27 2013, 10:48 PM
RonW ms3 or microsquirt Nov 27 2013, 11:04 PM
McMark MicroSquirt won't handle ignition on a six if ... Nov 27 2013, 11:25 PM
Mark Henry
MicroSquirt won't handle ignition on a six if... Nov 27 2013, 11:39 PM
iamchappy Im old school running a 86 Ruf CIS euro 930 fuel h... Nov 27 2013, 11:25 PM
Mark Henry
Im old school running a 86 Ruf CIS euro 930 fuel ... Nov 27 2013, 11:36 PM
Mark Henry So what I'm reading is the build time on an EC... Nov 28 2013, 06:44 AM
rick 918-S
So what I'm reading is the build time on an E... Nov 28 2013, 08:25 AM
Mark Henry
Same deal for me. I've been to the MS web s... Nov 28 2013, 08:40 AM
rick 918-S
Same deal for me. I've been to the MS web ... Nov 28 2013, 08:47 AM
Mark Henry
[quote name='Mark Henry' post='1963545' date='Nov... Nov 28 2013, 09:02 AM
rick 918-S
[quote name='Mark Henry' post='1963545' date='No... Nov 28 2013, 09:18 AM
jimkelly I believe you can get is assembled as well
http:/... Nov 28 2013, 10:05 AM
rick 918-S
http:... Nov 28 2013, 10:54 AM
DBCooper The SDS is "simple," which is good, but ... Nov 28 2013, 11:37 AM
Mark Henry
Ya, I was surfing the microsquirt site and there... Nov 28 2013, 11:45 AM
jeff This system is really nice, if money is no object ... Nov 28 2013, 11:05 AM
Mark Henry
This system is really nice, if money is no object... Nov 28 2013, 11:26 AM
rfuerst911sc If anyone is interested I have an Autronics unit I... Nov 28 2013, 12:28 PM
McMark The MegaSquirt main board has been through a few r... Nov 28 2013, 01:13 PM
Mark Henry
The MegaSquirt main board has been through a few ... Nov 28 2013, 01:31 PM
McMark You got it.
The CIS pump is higher pressure usual... Nov 28 2013, 02:42 PM
rick 918-S So like $ 500.00 and you still need to buy th... Nov 28 2013, 03:32 PM
Mark Henry
So like $ 500.00 and you still need to buy t... Nov 28 2013, 03:47 PM
rick 918-S
So like $ 500.00 and you still need to buy ... Nov 28 2013, 03:53 PM
Mark Henry
[quote name='Mark Henry' post='1963709' date='Nov... Nov 28 2013, 04:39 PM
McMark :agree: this is why my complete setup is $300... Nov 28 2013, 05:43 PM
Mark Henry
:agree: this is why my complete setup is $30... Nov 28 2013, 05:54 PM
ConeDodger
:agree: this is why my complete setup is $30... Nov 28 2013, 08:31 PM
r_towle
Mark, just a side thought on a totally different... Nov 29 2013, 04:06 PM
edwin I've been through this a few times now.
My fir... Nov 29 2013, 06:03 AM
Mark Henry
My fi... Nov 29 2013, 07:42 AM
sixnotfour I was going to run micro squirt, fuel only, but I ... Nov 29 2013, 02:14 PM
McMark Distributors have maintenance and timing settings,... Nov 29 2013, 04:39 PM
mikesmith
No distributor means it's all up to the ECU a... Nov 29 2013, 09:23 PM
McMark
No distributor means it's all up to the ECU ... Nov 29 2013, 09:35 PM
DBCooper yeah, but I can do COP way easier. So why would I ... Nov 30 2013, 03:09 PM
Mark Henry I got that dizzy dirt cheap for helping a bud with... Nov 29 2013, 05:05 PM
Mark Henry Well I'll wait on my /6 till the verdict is in... Nov 30 2013, 07:31 AM
rick 918-S I just came from Ross's house another local 91... Nov 30 2013, 02:51 PM
McMark Why would I add EDIS, when MicroSquirt can control... Nov 30 2013, 07:03 PM
DBCooper You don't need to use the EDIS module, that ge... Nov 30 2013, 08:01 PM
mikesmith Mark is (probably) talking about CNP using the GM ... Nov 30 2013, 08:14 PM
DBCooper Makes sense. I was curious because everyone aroun... Nov 30 2013, 08:27 PM
McMark Bosch makes a really easy ignitor as well for coil... Nov 30 2013, 10:50 PM
ConeDodger
Bosch makes a really easy ignitor as well for coi... Nov 30 2013, 10:56 PM
DBCooper Really? What an odd comment, Rob. Those coils ha... Dec 1 2013, 09:05 AM
ConeDodger
Really? What an odd comment, Rob. Those coils h... Dec 1 2013, 02:23 PM
jd74914
Bulletproof?? Really? The first time I saw an EDI... Dec 1 2013, 02:48 PM
McMark I looked at EDIS over the weekend. I still don... Dec 1 2013, 02:19 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:50 AM |
