| Mark Henry |
Nov 27 2013, 10:34 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Researching a FI system for a buddies late model 930, not much more than a low mile stock 3.4 engine with cams and a bit beefier snail.
I have another bud with a totally gonzo 930 with SDS, that car is a rocket (450+hp, extreme heads, paulter rods...etc.) and the SDS runs flawless on it, so SDS is in the running......But this guy has a clewette/electomotive crankfire (missing tooth) dual plug coilpack system already, so MS is a definite candidate as well. So what would be the best system that uses (ties into) the existing ignition? I can solder or would a finished system (like MS3 pro) be better? I know many of you have gone this route so I'm hoping to pick some brains. (IMG:style_emoticons/default/smile.gif) |
| McMark |
Nov 29 2013, 04:39 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Distributors have maintenance and timing settings, plus the advance curve is a PITA to change.
Single coil crank fire means you have to sync the FI signal and the physical orientation of the distributor, plus the advance mechanism may or may not be helpful. No distributor means it's all up to the ECU and you can change timing on the fly any way you want. Like anything else in this discussion, having options is powerful as long as you understand how to use them. If you're not ready/willing to take on the learning curve, go with a simple system. |
Mark Henry MS guru's! What MS for a /6 turbo? Nov 27 2013, 10:34 PM
McMark I got MSIII. Nov 27 2013, 10:48 PM
RonW ms3 or microsquirt Nov 27 2013, 11:04 PM
McMark MicroSquirt won't handle ignition on a six if ... Nov 27 2013, 11:25 PM
Mark Henry
MicroSquirt won't handle ignition on a six if... Nov 27 2013, 11:39 PM
iamchappy Im old school running a 86 Ruf CIS euro 930 fuel h... Nov 27 2013, 11:25 PM
Mark Henry
Im old school running a 86 Ruf CIS euro 930 fuel ... Nov 27 2013, 11:36 PM
Mark Henry So what I'm reading is the build time on an EC... Nov 28 2013, 06:44 AM
rick 918-S
So what I'm reading is the build time on an E... Nov 28 2013, 08:25 AM
Mark Henry
Same deal for me. I've been to the MS web s... Nov 28 2013, 08:40 AM
rick 918-S
Same deal for me. I've been to the MS web ... Nov 28 2013, 08:47 AM
Mark Henry
[quote name='Mark Henry' post='1963545' date='Nov... Nov 28 2013, 09:02 AM
rick 918-S
[quote name='Mark Henry' post='1963545' date='No... Nov 28 2013, 09:18 AM
jimkelly I believe you can get is assembled as well
http:/... Nov 28 2013, 10:05 AM
rick 918-S
http:... Nov 28 2013, 10:54 AM
DBCooper The SDS is "simple," which is good, but ... Nov 28 2013, 11:37 AM
Mark Henry
Ya, I was surfing the microsquirt site and there... Nov 28 2013, 11:45 AM
jeff This system is really nice, if money is no object ... Nov 28 2013, 11:05 AM
Mark Henry
This system is really nice, if money is no object... Nov 28 2013, 11:26 AM
rfuerst911sc If anyone is interested I have an Autronics unit I... Nov 28 2013, 12:28 PM
McMark The MegaSquirt main board has been through a few r... Nov 28 2013, 01:13 PM
Mark Henry
The MegaSquirt main board has been through a few ... Nov 28 2013, 01:31 PM
McMark You got it.
The CIS pump is higher pressure usual... Nov 28 2013, 02:42 PM
rick 918-S So like $ 500.00 and you still need to buy th... Nov 28 2013, 03:32 PM
Mark Henry
So like $ 500.00 and you still need to buy t... Nov 28 2013, 03:47 PM
rick 918-S
So like $ 500.00 and you still need to buy ... Nov 28 2013, 03:53 PM
Mark Henry
[quote name='Mark Henry' post='1963709' date='Nov... Nov 28 2013, 04:39 PM
McMark :agree: this is why my complete setup is $300... Nov 28 2013, 05:43 PM
Mark Henry
:agree: this is why my complete setup is $30... Nov 28 2013, 05:54 PM
ConeDodger
:agree: this is why my complete setup is $30... Nov 28 2013, 08:31 PM
Mark Henry Mark, just a side thought on a totally different e... Nov 28 2013, 08:26 PM
McMark
Mark, just a side thought on a totally different ... Nov 29 2013, 01:14 PM
Mark Henry
[quote name='Mark Henry' post='1963802' date='Nov... Nov 29 2013, 03:01 PM
r_towle
Mark, just a side thought on a totally different... Nov 29 2013, 04:06 PM
edwin I've been through this a few times now.
My fir... Nov 29 2013, 06:03 AM
Mark Henry
My fi... Nov 29 2013, 07:42 AM
sixnotfour I was going to run micro squirt, fuel only, but I ... Nov 29 2013, 02:14 PM
mikesmith
No distributor means it's all up to the ECU a... Nov 29 2013, 09:23 PM
McMark
No distributor means it's all up to the ECU ... Nov 29 2013, 09:35 PM
DBCooper yeah, but I can do COP way easier. So why would I ... Nov 30 2013, 03:09 PM
Mark Henry I got that dizzy dirt cheap for helping a bud with... Nov 29 2013, 05:05 PM
Mark Henry Well I'll wait on my /6 till the verdict is in... Nov 30 2013, 07:31 AM
rick 918-S I just came from Ross's house another local 91... Nov 30 2013, 02:51 PM
McMark Why would I add EDIS, when MicroSquirt can control... Nov 30 2013, 07:03 PM
DBCooper You don't need to use the EDIS module, that ge... Nov 30 2013, 08:01 PM
mikesmith Mark is (probably) talking about CNP using the GM ... Nov 30 2013, 08:14 PM
DBCooper Makes sense. I was curious because everyone aroun... Nov 30 2013, 08:27 PM
McMark Bosch makes a really easy ignitor as well for coil... Nov 30 2013, 10:50 PM
ConeDodger
Bosch makes a really easy ignitor as well for coi... Nov 30 2013, 10:56 PM
DBCooper Really? What an odd comment, Rob. Those coils ha... Dec 1 2013, 09:05 AM
ConeDodger
Really? What an odd comment, Rob. Those coils h... Dec 1 2013, 02:23 PM
jd74914
Bulletproof?? Really? The first time I saw an EDI... Dec 1 2013, 02:48 PM
McMark I looked at EDIS over the weekend. I still don... Dec 1 2013, 02:19 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:09 AM |
