> Throttle positioning sensor
partwerks
post Nov 24 2013, 10:16 AM
Just to confirm what I have been told. To replace the TPS on the 2004 Subaru WRX, I just need to take the 2 screws out, and put the new one in, and end of story?
http://www.ebay.com/itm/New-Throttle-Posit...1ec&vxp=mtr
partwerks
post Nov 29 2013, 07:32 PM
It does not have slotted holes.
The problem/bug that keeps lurking around it seems, is with the low idle.
My mechanic had me put on a new IACV, and that didn't change anything, then he put some gizmo to check the air fuel ratio, and was lean, and so put on a new 02 sensor, and fixed that problem, and he told me to adjust the idle set screw in is all to bring it up, and so I don't know if I did the wrong thing, but sometimes when shifting into 2nd, and let out the clutch it would sort of want to buck, and so I got the bringt idea to replace the TPS, since it was relatively cheap, and/or maybe that is the problem, after I put the new one in??
He also sprayed carb cleaner around to see if there were any vacum leaks, and couldn't find any.
I don't know if it matters, but I did not disconnect the battery, just took the screws out, and installed it.
Didn't seem to do anything for the low idle, and now if you really stick your foot into it, it is as though you were turning off the key, but if you back off a bit, it will run normal, or don't crowd it, and so I don't know if I gained anything or not, but thought about putting the old sensor back in??
Is there a way to check to see if the old sensor is working with an ohm meter? If so, I could have my electrician check it out.
- Lo-Fi Version Time is now: 2nd April 2026 - 09:49 AM
