> MS guru's! What MS for a /6 turbo?, researching and deciding on a system, bit OT, it's for a 930
Mark Henry
post Nov 27 2013, 10:34 PM
that's what I do!
Researching a FI system for a buddies late model 930, not much more than a low mile stock 3.4 engine with cams and a bit beefier snail.
I have another bud with a totally gonzo 930 with SDS, that car is a rocket (450+hp, extreme heads, paulter rods...etc.) and the SDS runs flawless on it, so SDS is in the running......But this guy has a clewette/electomotive crankfire (missing tooth) dual plug coilpack system already, so MS is a definite candidate as well.
So what would be the best system that uses (ties into) the existing ignition?
I can solder or would a finished system (like MS3 pro) be better?
I know many of you have gone this route so I'm hoping to pick some brains. (IMG:style_emoticons/default/smile.gif)
McMark
post Nov 29 2013, 04:39 PM
914 Freak!
Distributors have maintenance and timing settings, plus the advance curve is a PITA to change.
Single coil crank fire means you have to sync the FI signal and the physical orientation of the distributor, plus the advance mechanism may or may not be helpful.
No distributor means it's all up to the ECU and you can change timing on the fly any way you want.
Like anything else in this discussion, having options is powerful as long as you understand how to use them. If you're not ready/willing to take on the learning curve, go with a simple system.
mikesmith
post Nov 29 2013, 09:23 PM
QUOTE(McMark @ Nov 29 2013, 02:39 PM) *
To be fair, you can do ECU-controlled ignition timing with a distributor; all the 'distributor' part does is pick which plug gets the spark over a very wide range of time.
What you need for ECU-controlled timing is an engine position reference (e.g. cam angle) and controlled spark generation. Look at the GM "small cap" EFI distributors for example, or the MS examples here: http://www.msextra.com/doc/ms3/ignition.html
(there doesn't appear to be a teaching-your-grandmother-to-suck-eggs smiley, sorry...)
McMark
post Nov 29 2013, 09:35 PM
914 Freak!
QUOTE(mikesmith @ Nov 29 2013, 07:23 PM) *
yeah, but I can do COP way easier. So why would I ever bother. (IMG:style_emoticons/default/wink.gif)
DBCooper
post Nov 30 2013, 03:09 PM
14's in the 13's with ATTITUDE
QUOTE(McMark @ Nov 29 2013, 07:35 PM) *
Easier than an EDIS coil pack?
Mark Henry   MS guru's! What MS for a /6 turbo?   Nov 27 2013, 10:34 PM
McMark   I got MSIII.   Nov 27 2013, 10:48 PM
RonW   ms3 or microsquirt   Nov 27 2013, 11:04 PM
McMark   MicroSquirt won't handle ignition on a six if ...   Nov 27 2013, 11:25 PM
Mark Henry   MicroSquirt won't handle ignition on a six if...   Nov 27 2013, 11:39 PM
iamchappy   Im old school running a 86 Ruf CIS euro 930 fuel h...   Nov 27 2013, 11:25 PM
Mark Henry   Im old school running a 86 Ruf CIS euro 930 fuel ...   Nov 27 2013, 11:36 PM
Mark Henry   So what I'm reading is the build time on an EC...   Nov 28 2013, 06:44 AM
rick 918-S   So what I'm reading is the build time on an E...   Nov 28 2013, 08:25 AM
Mark Henry   Same deal for me. I've been to the MS web s...   Nov 28 2013, 08:40 AM
rick 918-S   Same deal for me. I've been to the MS web ...   Nov 28 2013, 08:47 AM
Mark Henry   [quote name='Mark Henry' post='1963545' date='Nov...   Nov 28 2013, 09:02 AM
rick 918-S   [quote name='Mark Henry' post='1963545' date='No...   Nov 28 2013, 09:18 AM
jimkelly   I believe you can get is assembled as well http:/...   Nov 28 2013, 10:05 AM
rick 918-S   I believe you can get is assembled as well http:...   Nov 28 2013, 10:54 AM
DBCooper   The SDS is "simple," which is good, but ...   Nov 28 2013, 11:37 AM
Mark Henry   Ya, I was surfing the microsquirt site and there...   Nov 28 2013, 11:45 AM
jeff   This system is really nice, if money is no object ...   Nov 28 2013, 11:05 AM
Mark Henry   This system is really nice, if money is no object...   Nov 28 2013, 11:26 AM
rfuerst911sc   If anyone is interested I have an Autronics unit I...   Nov 28 2013, 12:28 PM
McMark   The MegaSquirt main board has been through a few r...   Nov 28 2013, 01:13 PM
Mark Henry   The MegaSquirt main board has been through a few ...   Nov 28 2013, 01:31 PM
McMark   You got it. The CIS pump is higher pressure usual...   Nov 28 2013, 02:42 PM
rick 918-S   So like $ 500.00 and you still need to buy th...   Nov 28 2013, 03:32 PM
Mark Henry   So like $ 500.00 and you still need to buy t...   Nov 28 2013, 03:47 PM
rick 918-S   So like $ 500.00 and you still need to buy ...   Nov 28 2013, 03:53 PM
Mark Henry   [quote name='Mark Henry' post='1963709' date='Nov...   Nov 28 2013, 04:39 PM
McMark   :agree: this is why my complete setup is $300...   Nov 28 2013, 05:43 PM
Mark Henry   :agree: this is why my complete setup is $30...   Nov 28 2013, 05:54 PM
ConeDodger   :agree: this is why my complete setup is $30...   Nov 28 2013, 08:31 PM
Mark Henry   Mark, just a side thought on a totally different e...   Nov 28 2013, 08:26 PM
McMark   Mark, just a side thought on a totally different ...   Nov 29 2013, 01:14 PM
Mark Henry   [quote name='Mark Henry' post='1963802' date='Nov...   Nov 29 2013, 03:01 PM
r_towle   Mark, just a side thought on a totally different...   Nov 29 2013, 04:06 PM
edwin   I've been through this a few times now. My fir...   Nov 29 2013, 06:03 AM
Mark Henry   I've been through this a few times now. My fi...   Nov 29 2013, 07:42 AM
sixnotfour   I was going to run micro squirt, fuel only, but I ...   Nov 29 2013, 02:14 PM
McMark   Distributors have maintenance and timing settings,...   Nov 29 2013, 04:39 PM
mikesmith   No distributor means it's all up to the ECU a...   Nov 29 2013, 09:23 PM
McMark   No distributor means it's all up to the ECU ...   Nov 29 2013, 09:35 PM
DBCooper   yeah, but I can do COP way easier. So why would I ...   Nov 30 2013, 03:09 PM
Mark Henry   I got that dizzy dirt cheap for helping a bud with...   Nov 29 2013, 05:05 PM
Mark Henry   Well I'll wait on my /6 till the verdict is in...   Nov 30 2013, 07:31 AM
rick 918-S   I just came from Ross's house another local 91...   Nov 30 2013, 02:51 PM
McMark   Why would I add EDIS, when MicroSquirt can control...   Nov 30 2013, 07:03 PM
DBCooper   You don't need to use the EDIS module, that ge...   Nov 30 2013, 08:01 PM
mikesmith   Mark is (probably) talking about CNP using the GM ...   Nov 30 2013, 08:14 PM
DBCooper   Makes sense. I was curious because everyone aroun...   Nov 30 2013, 08:27 PM
McMark   Bosch makes a really easy ignitor as well for coil...   Nov 30 2013, 10:50 PM
ConeDodger   Bosch makes a really easy ignitor as well for coi...   Nov 30 2013, 10:56 PM
DBCooper   Really? What an odd comment, Rob. Those coils ha...   Dec 1 2013, 09:05 AM
ConeDodger   Really? What an odd comment, Rob. Those coils h...   Dec 1 2013, 02:23 PM
jd74914   Bulletproof?? Really? The first time I saw an EDI...   Dec 1 2013, 02:48 PM
McMark   I looked at EDIS over the weekend. I still don...   Dec 1 2013, 02:19 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:45 AM
