> Dremel Grinding Tool, which bit works best on welds?
seanery
post Jul 28 2004, 08:20 PM
waiting to rebuild whitey!
I'm grinding mild steel welds on my bike to get it ready for plating.
I used this bit this evening. It only lasted an hour or hour and a half.
(IMG:http://dremel.com/html/images/products/bits/large/194.gif)
Is there a better bit?
I've got some abrasive tips for the air powered die grinder, but I don't think the compressor will keep up with hours of grinding.
bondo
post Jul 28 2004, 09:38 PM
QUOTE(Mueller @ Jul 28 2004, 08:33 PM)
the problem with the carbide cutters is that it is very easy for the tool to "ran away" from you, or at least that is my experiance (too much coffee???)
I have more trouble with that using dremel tools than with die grinders.. not sure why.
seanery   Dremel Grinding Tool   Jul 28 2004, 08:20 PM
TimT   Probably the best would be a diamond impregnated b...   Jul 28 2004, 08:38 PM
kafermeister   Hmm. I've never had much luck w/Dremel for gr...   Jul 28 2004, 08:48 PM
seanery   yeah, I'm trying to make it pretty. I want to ...   Jul 28 2004, 09:06 PM
bondo   Carbide cutters for a die grinder are the best I...   Jul 28 2004, 09:27 PM
Mueller   Sean, if you have the room, I think the small cut...   Jul 28 2004, 09:31 PM
Mueller   the problem with the carbide cutters is that it is...   Jul 28 2004, 09:33 PM
bondo   <...   Jul 28 2004, 09:38 PM
lapuwali   My experience with the Dremel cutoff wheels is the...   Jul 28 2004, 09:48 PM
Mueller   I had to use a dremel cutoff wheel last week to re...   Jul 28 2004, 09:58 PM
thomasotten   I used the carbide tip to remove the jack post sup...   Jul 28 2004, 11:36 PM
9146986   Dremel is a good tool, but it's a hobby tool. ...   Jul 29 2004, 12:02 AM
J P Stein   :agree:   Jul 29 2004, 02:05 AM
seanery   Alright, I'll give the air tools a shot. I hop...   Jul 29 2004, 08:11 AM
jonwatts   <...   Jul 29 2004, 08:57 AM
jkeyzer   <...   Jul 29 2004, 09:34 AM
seanery   I found these and other bits at: American Carbide ...   Jul 29 2004, 11:03 AM
J P Stein   That cone radius ruby is one of those I use.....an...   Jul 29 2004, 11:57 AM
seanery   I ended up buying these carbide bits from the vend...   Jul 29 2004, 04:27 PM
seanery   One more question, cutting oil or no cutting oil?   Jul 29 2004, 04:31 PM
Aaron Cox   hows your lowrider bike coming?   Jul 29 2004, 04:38 PM
seanery   still gathering parts, almost done. Just need to o...   Jul 29 2004, 04:49 PM
Aaron Cox   dude...what spawned the creation of this bike? its...   Jul 29 2004, 05:32 PM
seanery   Here's what I've got for the bike: Electra...   Jul 29 2004, 06:49 PM
Aaron Cox   copper plated? jesse james style ;)   Jul 29 2004, 06:51 PM
- Lo-Fi Version Time is now: 13th March 2026 - 01:33 PM
