Introduction, new 914/4 owner |
Seabird |
Nov 23 2013, 02:49 PM
Member Group: Members Posts: 165 Joined: 21-November 13 From: United States Member No.: 16,683 Region Association: South East States |
Afternoon everyone!
Yesterday I purchased my first 914/4! Just got back this afternoon for the long tow home. I pulled a regular Peter Egan; driving 8 hours across at least one time zone to drag a forgotten toy out from someone else's over crowed garage! Here she is: (IMG:http://www.914world.com/bbs2/uploads_offsite/dl.dropboxusercontent.com-16683-1385392013.1.jpg) One of the PO's started a race car transformation on her a number of years back, had one outing on the track, and then it went into storage. A lot of the race items are out of certification which is fine as I am not going racing soon. The motor has had some work done to it (PO claimed 130 at the wheels) and she has been lightened quite a bit (again PO claimed 1735#s). The PO claimed it to be an LE. Apparently they are fairly rare. Shame that it was hacked up to make into a race car. The chassis is straight and solid. Some minor surface rust in the wheel wells. The battery hole is rock solid. And there is a real nice roll cage welded in. The brakes and suspension have had some major work too! 911 brakes and koni adjust able shocks front and rear. There are a couple of items that are a little annoying... The biggest one is the front trunk has a gaping hole in the center. My brother said thats where the factory a/c would have been installed (IMG:style_emoticons/default/confused24.gif) I will need to find someone parting out a car and fill this. Also someone bugger up the carb linkage. 1/2" balled end on the hex rod is bent something nasty. Will need to find one of those. I bought her with the intent of using her for DE and maybe eventually going vintage racing. I have been using a big block e30, 3.5L m30, for DE with NASA but I wanted to get into something a little older and lighter; I think I succeeded! (IMG:style_emoticons/default/biggrin.gif) First thing I did when I got it home was to drain the fuel and add fresh gas and a new fuel filter. With fresh gas in the system I was able to get her cranked up and running. On a high idle she will stay running but when off the throttle she conchs out. I order a set of carb rebuild kits. I am sure 5 years of sitting in a garage did in the accelerator pumps and floats and jets and...well then need to get rebuild. |
Randal |
Nov 26 2013, 10:05 AM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
About that oil cooler. When I bought my car the PO in Carson City, Nev. had installed an oil cooler, with a 600cfm fan underneath the engine cover. Like one unit.
It actually worked good and I ran that configuration at Button Willow when it was HOT. Never had high oil temperatures, but the heat coming into the compartment wilted everything. So changed the configuration a bit (see the link) and had it suck the air out of the engine compartment and it worked good. The revised configuration had 1600cfm fan. Sold it to Dan Thompson who then installed it in his front trunk exiting downward. There are pictures here somewhere... More here: http://www.914world.com/bbs2/index.php?sho...ic=8146&hl= |
Randal |
Nov 26 2013, 10:11 AM
About that oil cooler. When I bought my car the PO in Carson City, Nev. had installed an oil cooler, with a big fan underneath the engine cover. Like one unit. It actually worked good and I ran that configuration at Button Willow when it was HOT. Never had high oil temperatures. Sold it to Dan Thompson who then installed it in his front trunk exiting downward. There are pictures here somewhere... The magic of search.. http://www.914world.com/bbs2/index.php?sho...p;hl=oil+cooler Forgot how nice that unit was. We build a flat plate that the cooler was attached to, then mounted the fan on a round aluminum piece that acted like a shroud. I kind of like where Dan put it, but it also worked great mounted under the engine cover, with the shroud configuration and bigger fan. |
Seabird |
Nov 26 2013, 02:00 PM
The magic of search.. http://www.914world.com/bbs2/index.php?sho...p;hl=oil+cooler Forgot how nice that unit was. We build a flat plate that the cooler was attached to, then mounted the fan on a round aluminum piece that acted like a shroud. I kind of like where Dan put it, but it also worked great mounted under the engine cover, with the shroud configuration and bigger fan. Thanks for the ideas Randal! I am leaning towards a rear mounted solution to keep the front free for a fuel cell when the time comes. As a six is not on the horizon I probably will not have the need to disturb the front of the car with an oil cooler. I have a couple of oil cooler questions though, whats the deal with the stock one? Does this just get abandoned when a remote is added? If so should it be removed? And lastly, is there a reason folks aren't make use of the heater ducts to pipe fresh air from the front to the rear? Seems like half the work is already done! Pull the air from right in front of the windshield where the pressure increases and push it back to either side of the engine right onto the heads! Use a little cowling like this and you'll get a ton of air. Jeep accessories Just some thoughts Miguel |
Jetsetsurfshop |
Dec 2 2013, 07:36 PM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
QUOTE And lastly, is there a reason folks aren't make use of the heater ducts to pipe fresh air from the front to the rear? Seems like half the work is already done! Pull the air from right in front of the windshield where the pressure increases and push it back to either side of the engine right onto the heads! Use a little cowling like this and you'll get a ton of air. Jeep accessories Just some thoughts Miguel I've always thought this was a good idea. What are you planing to do with the "fresh air"? What about NACA ducts on the hood? |
Lo-Fi Version | Time is now: 6th June 2024 - 10:36 AM |
