| seanery |
Jul 28 2004, 08:20 PM
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
I'm grinding mild steel welds on my bike to get it ready for plating.
I used this bit this evening. It only lasted an hour or hour and a half. (IMG:http://dremel.com/html/images/products/bits/large/194.gif) Is there a better bit? I've got some abrasive tips for the air powered die grinder, but I don't think the compressor will keep up with hours of grinding. |
| Mueller |
Jul 28 2004, 09:58 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
I had to use a dremel cutoff wheel last week to remove the head of a stripped CV joint bolt (IMG:style_emoticons/default/sad.gif)
seanery Dremel Grinding Tool Jul 28 2004, 08:20 PM
TimT Probably the best would be a diamond impregnated b... Jul 28 2004, 08:38 PM
kafermeister Hmm. I've never had much luck w/Dremel for gr... Jul 28 2004, 08:48 PM
seanery yeah, I'm trying to make it pretty. I want to ... Jul 28 2004, 09:06 PM
bondo Carbide cutters for a die grinder are the best I... Jul 28 2004, 09:27 PM
Mueller Sean,
if you have the room, I think the small cut... Jul 28 2004, 09:31 PM
Mueller the problem with the carbide cutters is that it is... Jul 28 2004, 09:33 PM
bondo <... Jul 28 2004, 09:38 PM
lapuwali My experience with the Dremel cutoff wheels is the... Jul 28 2004, 09:48 PM
thomasotten I used the carbide tip to remove the jack post sup... Jul 28 2004, 11:36 PM
9146986 Dremel is a good tool, but it's a hobby tool. ... Jul 29 2004, 12:02 AM
J P Stein :agree: Jul 29 2004, 02:05 AM
seanery Alright, I'll give the air tools a shot. I hop... Jul 29 2004, 08:11 AM
jonwatts <... Jul 29 2004, 08:57 AM
jkeyzer <... Jul 29 2004, 09:34 AM
seanery I found these and other bits at: American Carbide
... Jul 29 2004, 11:03 AM
J P Stein That cone radius ruby is one of those I use.....an... Jul 29 2004, 11:57 AM
seanery I ended up buying these carbide bits from the vend... Jul 29 2004, 04:27 PM
seanery One more question, cutting oil or no cutting oil? Jul 29 2004, 04:31 PM
Aaron Cox hows your lowrider bike coming? Jul 29 2004, 04:38 PM
seanery still gathering parts, almost done. Just need to o... Jul 29 2004, 04:49 PM
Aaron Cox dude...what spawned the creation of this bike? its... Jul 29 2004, 05:32 PM
seanery Here's what I've got for the bike:
Electra... Jul 29 2004, 06:49 PM
Aaron Cox copper plated? jesse james style ;) Jul 29 2004, 06:51 PM![]() ![]() |
Lo-Fi Version | Time is now: 13th March 2026 - 01:33 PM |
