Windshield frame replacement? |
Mwood |
Dec 3 2013, 10:35 PM
Member Group: Members Posts: 56 Joined: 11-February 13 From: Bay Area Member No.: 15,509 Region Association: Northern California |
This is a foolish question but I figure that it wont hurt to
The previous owner of my car, as well as welding a cage bar directly behind the drivers seat that limited how far back it can go by about 8 inches, decided to chop and angle back the windshield frame of my car 10 degrees. Apparently this was for attempted gains in aerodynamics. I have access to a parts car with a good windshield frame and I want to be able to run a roof. What is the easiest way to replace the whole windshield frame on a 914? If the piece that includes the frame and cowl and wiper motor can be removed thats easiest.. If i would have to chop it and jig it and weld on a new one Ill just wait on the whole thing.. Ideas? Also, if anyone has a link to a diy on removing the sleeve on the wiring harness that goes through the firewall behind the cabin that would be helpful im trying to pull the whole harness. Thank you Mitch |
Mike Bellis |
Dec 3 2013, 10:53 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Also, if anyone has a link to a diy on removing the sleeve on the wiring harness that goes through the firewall behind the cabin that would be helpful im trying to pull the whole harness. Thank you Mitch You leave it on the wires and pull the entire thing through into the cabin. Once in the cabin, you can carefully slide the rubber sleeve off. It's not easy. |
Lo-Fi Version | Time is now: 4th June 2024 - 02:44 PM |
