License plate illumination, on early bumpers |
malcolm2 |
Dec 3 2013, 02:46 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I have removed the BUBS on my 75 and installed 73 painted black. I know I took the LP lights off of the BUB, but who knows where they are and I don't think they are a match for the early bumpers.
What do folks do? This seems like an item I could go to a trailer store for. Or are the OEM lights out there? They look like they were attached with sheet metal screws to the underside of the rear bumper top. Thanks. |
dlestep |
Dec 4 2013, 10:28 AM
I am smilin'... Group: Members Posts: 890 Joined: 15-January 08 From: Sunrise Florida Member No.: 8,573 Region Association: South East States |
Last year, I found a different source for license plate illumination. I plan to use
them (2x) on my Ghia. They are license plate bolts that have a LED in the head of the bolt and a little cut on the side of it exposing the LED to illuminate the plate. I didn't want to run a license plate frame, nor the original license plate housing on the Ghia. http://www.ebay.com/itm/like/300442806023?lpid=82 |
sfrenck |
Dec 6 2013, 06:09 AM
Member Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region |
Last year, I found a different source for license plate illumination. I plan to use them (2x) on my Ghia. They are license plate bolts that have a LED in the head of the bolt and a little cut on the side of it exposing the LED to illuminate the plate. I didn't want to run a license plate frame, nor the original license plate housing on the Ghia. http://www.ebay.com/itm/like/300442806023?lpid=82 I used these for a bit until I found the correct ones. They also can be purchased at PepBoys |
malcolm2 |
Dec 6 2013, 08:25 AM
Last year, I found a different source for license plate illumination. I plan to use them (2x) on my Ghia. They are license plate bolts that have a LED in the head of the bolt and a little cut on the side of it exposing the LED to illuminate the plate. I didn't want to run a license plate frame, nor the original license plate housing on the Ghia. http://www.ebay.com/itm/like/300442806023?lpid=82 I used these for a bit until I found the correct ones. They also can be purchased at PepBoys Do you have the "H" bracket for the license plate? How do these LED bolt lights fit? Seems to me that the threaded bolt is too long. And the plate mounting holes in the "H" shaped LP bracket are very small. I had to use sheet metal screws, very short ones. The bracket is pretty tight to the bumper. I think I am using the "H" bracket from my 75 bumper. Are the early brackets different? |
Lo-Fi Version | Time is now: 13th June 2024 - 03:31 PM |
