> LED H4 conversion
Harpo
post Dec 7 2013, 10:31 AM
This seems too good to be true. If the seller had a higher rating I might consider it.
http://www.ebay.com/itm/LED-Headlight-Conv...300442806023%26
David
gothspeed
post Dec 9 2013, 05:07 AM
I have seen those truck lights, they have a divder which illustrates that only the upper half (or 180 degrees) is used for low beam. The lower half for high beam.
However in this case I would prefer the HID retrofit. I don't like how due to the divider, only half of the refector is illuminated. I am sure they function fairly well, but they sure do look kinda strange. (IMG:style_emoticons/default/wacko.gif)
On another note, the outer lense appears to extend further than a 'normal' 'domed front' bulb. So they may interfere with the trim peice in front of the headlight, during pop-up/down travel.
Harpo   LED H4 conversion   Dec 7 2013, 10:31 AM
JmuRiz   Very interesting, I know nada about lights etc...w...   Dec 7 2013, 01:25 PM
billh1963   That is cool. I wonder about longevity, legality, ...   Dec 7 2013, 01:39 PM
pcar916   This is bulbs and electronics for later cars that ...   Dec 7 2013, 02:18 PM
Spoke   ... but fans? Really. Contrary to marketing of l...   Dec 7 2013, 02:59 PM
gothspeed   So far i was gonna go HID, because they draw less ...   Dec 7 2013, 02:22 PM
mikesmith   These are going to give you a weird light throw pa...   Dec 7 2013, 02:28 PM
Mike Bellis   If your reflector in the lens is not setup for the...   Dec 7 2013, 02:33 PM
gothspeed   The only time you need 360 degree light is during ...   Dec 7 2013, 02:37 PM
mikesmith   The light output from a planar LED like this is no...   Dec 7 2013, 02:57 PM
mikesmith   ... and that someone is at least *trying* to do th...   Dec 7 2013, 03:12 PM
gothspeed   It would actually be a good thing that more light ...   Dec 7 2013, 03:13 PM
mikesmith   It's not going to be "on axis" becau...   Dec 7 2013, 10:58 PM
gothspeed   The whole point of the parabolic reflector is to e...   Dec 7 2013, 11:31 PM
Eric_Shea   Back to the "I doubt it would fit with the fa...   Dec 8 2013, 09:41 AM
mikesmith   I'm not done with "you don't seem to ...   Dec 8 2013, 02:05 PM
gothspeed   Light from a projector is 'focused' to a v...   Dec 8 2013, 08:20 PM
tomeric914   Not cheap, but well known in the HD trucking indus...   Dec 8 2013, 10:03 PM
mikesmith   I mentioned these earlier. The GE units are just r...   Dec 8 2013, 11:11 PM
gothspeed   I have seen those truck lights, they have a divder...   Dec 9 2013, 05:07 AM
wndsnd   If you are buying these for long life consider thi...   Dec 9 2013, 08:22 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 04:47 PM
