| seanery |
Jul 28 2004, 08:20 PM
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
I'm grinding mild steel welds on my bike to get it ready for plating.
I used this bit this evening. It only lasted an hour or hour and a half. (IMG:http://dremel.com/html/images/products/bits/large/194.gif) Is there a better bit? I've got some abrasive tips for the air powered die grinder, but I don't think the compressor will keep up with hours of grinding. |
| seanery |
Jul 29 2004, 06:49 PM
Here's what I've got for the bike:
Electra Bike Springer Fork 26x2.125 Electra Hotster Red Stripe w/Flame Tread Front Tire 24x3.00 Electra Fatti-O Rear Tire (It's friggen HUGE FAT!) SRAM Spectro P5 5 Speed Internal Rear Hub with Coaster Brake (shifter will get mounted on seat tube and cables hidden) Brooks B-66 Honey Colored Leather Saddle (Old School Style) Tioga 1" Threaded Headset 68x113 Truvativ Giga SL Bottom Bracket Truvativ BMX to Euro BB Conversion Kit Electra Cruiser Bars Cinelli Quill Stem Adapter Cinelli Groove Stem 3T Stem (don't know which of these I'll like best) Shimano Deore LX 570 32 Hole Front Hub I still have left to get: Truvativ Stylo SS or FireX SS Crankset AlexRims DX32 24" x 39.1mm Rear Rim AlexRims DM18 26" x 24.2mm Front Rim Some flavor of pedal - I'm leaning towards Crank Brothers Egg Beaters Ti The whole frame will get Copper Plated - as thick as they will allow - without any clear so it can age and tarnish Handlebars & springer will get Blackened - I've gotta find someone to do this, it seems like a cool process I'm not sure what I'll do with the rims and hubs. The rims come black and one hub is black the other is clear aluminum-probably Nickel Plated Cranks will either get Blackened or Nickel Plated that's it for now. I hope the burrs come in soon, I've got a loooooooot of work to get the frame ready. (IMG:style_emoticons/default/smash.gif) |
seanery Dremel Grinding Tool Jul 28 2004, 08:20 PM
TimT Probably the best would be a diamond impregnated b... Jul 28 2004, 08:38 PM
kafermeister Hmm. I've never had much luck w/Dremel for gr... Jul 28 2004, 08:48 PM
seanery yeah, I'm trying to make it pretty. I want to ... Jul 28 2004, 09:06 PM
bondo Carbide cutters for a die grinder are the best I... Jul 28 2004, 09:27 PM
Mueller Sean,
if you have the room, I think the small cut... Jul 28 2004, 09:31 PM
Mueller the problem with the carbide cutters is that it is... Jul 28 2004, 09:33 PM
bondo <... Jul 28 2004, 09:38 PM
lapuwali My experience with the Dremel cutoff wheels is the... Jul 28 2004, 09:48 PM
Mueller I had to use a dremel cutoff wheel last week to re... Jul 28 2004, 09:58 PM
thomasotten I used the carbide tip to remove the jack post sup... Jul 28 2004, 11:36 PM
9146986 Dremel is a good tool, but it's a hobby tool. ... Jul 29 2004, 12:02 AM
J P Stein :agree: Jul 29 2004, 02:05 AM
seanery Alright, I'll give the air tools a shot. I hop... Jul 29 2004, 08:11 AM
jonwatts <... Jul 29 2004, 08:57 AM
jkeyzer <... Jul 29 2004, 09:34 AM
seanery I found these and other bits at: American Carbide
... Jul 29 2004, 11:03 AM
J P Stein That cone radius ruby is one of those I use.....an... Jul 29 2004, 11:57 AM
seanery I ended up buying these carbide bits from the vend... Jul 29 2004, 04:27 PM
seanery One more question, cutting oil or no cutting oil? Jul 29 2004, 04:31 PM
Aaron Cox hows your lowrider bike coming? Jul 29 2004, 04:38 PM
seanery still gathering parts, almost done. Just need to o... Jul 29 2004, 04:49 PM
Aaron Cox dude...what spawned the creation of this bike? its... Jul 29 2004, 05:32 PM
Aaron Cox copper plated? jesse james style ;) Jul 29 2004, 06:51 PM![]() ![]() |
Lo-Fi Version | Time is now: 13th March 2026 - 01:38 PM |
