gryphon68 |
Member ![]() ![]() Group: Members Posts: 61 Joined: 2-October 13 From: SE Michigan Member No.: 16,462 Region Association: Upper MidWest ![]() |
What is the best match for rear brake calipers if I am planning a 5-lug conversion with 1970 911T Struts and hubs? Leaning towards the 3" Brembo Aluminum calipers in front, the lightweight is a big plus in my opinion.
Hoping to use the 911 parking brake in the back, so no need for complicated rear calipers with internal parking brake. Besides a 3" M-Caliper (38mm?) what are the other options for the rear calipers? Something lightweight would be a bonus . . . If I where to run a dual master cylinder pedal with balance bar would it be possible to just use another set of the 48mm Brembo Aluminum calipers on the rear? |
shoguneagle |
shoguneagle ![]() ![]() ![]() Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California ![]() |
911 brakes boil down to the different connections and cables required for these brakes vs normal 914. Do talk to Eric which I believe is the best source for this information.
Do research on this board and you will find a wealth of information. Tangerine Racing has a modification to the 914 cables which adapt to the 911 brakes. |
Lo-Fi Version | Time is now: 1st July 2025 - 07:52 AM |
