| moggy |
Jun 22 2013, 02:38 AM
Member ![]() ![]() Group: Members Posts: 192 Joined: 15-December 04 From: Wales Member No.: 3,285 |
It's time I moved out of the dark ages and got myself a dry sump system on the rallycar. What's everyone using? Any pictures of installations? especially with the stock cooling. My concern is that I'll have to do some major surgery on the fan shroud (4 cylinder engine) as any dry sump pump will sit so far proud that I'll have to cut a hole in the fan shroud. Really interested to see what everyone has done. (IMG:style_emoticons/default/beerchug.gif)
| Borderline |
Dec 11 2013, 12:30 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 8-February 05 From: San Juan Bautista, CA Member No.: 3,577 Region Association: Northern California |
It's been a while since I did my engine build, but I remember the Type 4 oil pump being slight larger in diameter than the Type 1. I bought a pump from fat Performance that had an O-ring placed around the body to seal in the case. Are there oil pumps now that are designed for Type 4 engines? If not, how are you handling the size difference in pumps?
moggy Dry sump systems Jun 22 2013, 02:38 AM
tomeric914 I was going to go dry sump with the four, but swit... Jun 22 2013, 12:15 PM
McMark I bought a TypeI Auto-Stick oil pump with fits in ... Jun 22 2013, 05:44 PM
Matt Romanowski I would be concerned with the scavenge on that pum... Jun 22 2013, 07:22 PM
moggy Thanks for the feedback so far guys. I've done... Jun 23 2013, 03:33 PM
bam914 Get a pump from Thorsten Pieper. It is a 2 stage ... Jun 23 2013, 04:37 PM
moggy
Get a pump from Thorsten Pieper. It is a 2 stage... Jun 23 2013, 11:59 PM
Racer Chris I use the CB 2 rotor pumps.
The front inlet and ou... Jun 23 2013, 04:39 PM
Randal
The front inlet and o... Jun 23 2013, 08:25 PM
dlestep
Do you get additional HP by running a dry sump oi... Jun 23 2013, 08:46 PM
bam914 It was over $400.00. He is in Germany. You ... Jun 24 2013, 09:43 AM
moggy
It was over $400.00. He is in Germany. You... Jun 25 2013, 01:06 AM
moggy I'm going for the Thorsten Pieper pump (Thanks... Jun 28 2013, 12:00 PM
moggy
It was over $400.00. He is in Germany. You... Dec 8 2013, 02:59 PM
bam914
It was over $400.00. He is in Germany. Yo... Dec 9 2013, 09:44 PM
moggy
Never got to that point. Sorry
No worries :bee... Dec 11 2013, 05:39 AM
r_towle If you go to the 911 cooling shroud, everything fi... Jun 24 2013, 03:40 PM
moggy Quick question.....
What do I do with the current... Jun 28 2013, 12:42 PM
moggy
Quick question.....
What do I do with the curren... Jul 8 2013, 02:42 PM
yeahmag My build shows most everything you need to know:
... Jun 28 2013, 05:27 PM
stugray Anyone have complete diagrams?
I have read most o... Jul 5 2013, 08:24 PM
yeahmag RE: Dry sump systems Jul 6 2013, 09:01 AM
stugray That helps but it doesnt show the other half.
That... Jul 6 2013, 12:02 PM
john rogers Some things to remember about dry sump systems.
- ... Jul 7 2013, 07:28 PM
moggy
-... Jul 8 2013, 02:39 PM
Racer Chris You will need to loop them together, not block the... Jul 8 2013, 03:54 PM
moggy
You will need to loop them together, not block th... Jul 9 2013, 03:17 PM
moggy
You will need to loop them together, not block th... Jul 9 2013, 04:09 PM
Racer Chris That looks like just the ticket. Jul 9 2013, 06:28 PM
yeahmag I used a single peace of strong angle iron and onl... Dec 11 2013, 12:48 PM
moggy Aaron - I looked at that option but decided agains... Dec 12 2013, 09:02 AM
pcar916 ... as well you'll have to calculate the prope... Dec 12 2013, 09:31 AM![]() ![]() |
Lo-Fi Version | Time is now: 23rd October 2025 - 08:17 PM |
