gryphon68 |
Member ![]() ![]() Group: Members Posts: 61 Joined: 2-October 13 From: SE Michigan Member No.: 16,462 Region Association: Upper MidWest ![]() |
What is the best match for rear brake calipers if I am planning a 5-lug conversion with 1970 911T Struts and hubs? Leaning towards the 3" Brembo Aluminum calipers in front, the lightweight is a big plus in my opinion.
Hoping to use the 911 parking brake in the back, so no need for complicated rear calipers with internal parking brake. Besides a 3" M-Caliper (38mm?) what are the other options for the rear calipers? Something lightweight would be a bonus . . . If I where to run a dual master cylinder pedal with balance bar would it be possible to just use another set of the 48mm Brembo Aluminum calipers on the rear? |
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,096 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
I have been thinking the Aluminum Brembos on my 911T front struts with Eric's Aluminium 914/6 rear calipers should be a prefect set up. More brakes than my narrow body 914 will ever need, in a 205 width even sticky "race" tires will only provide so much grip.
Not cheap as in a couple hundred bucks but for a good brake set up it is cheap. Save on un-sprung weight and get a balanced brake system that is bolt on. Jim |
Lo-Fi Version | Time is now: 1st July 2025 - 10:49 AM |
